Help reassembling knuckle
Santa Rosa, CA
Anyone in the Santa Rosa (northern Calif) that wants to sit on a cooler and drink beer while I reassemble a knuckle (for the first time) and tell me how I'm doing it wrong.
this is the age of live stream you don't need real people. :) Good thing is it aint hard just messy and if you get stuck plenty of guys on here who can do them sleeping
It's not the stuff the FSM tells you, that's easy, it's all the thing that require technique or tools. Getting the bearing races out, getting the bearing races in, etc., etc., Getting the knuckle back together with the trunion bearings properly mounted top and bottom. All of them have us scratching our heads on how to actually make it happen.
Trunion bearings and races are the easy part. Just tap out the races with a hammer and punch and tap in new ones with something soft like a brass hammer.
Doing the job without getting grease all over your damn self and without tracking it inside the house is the hard part.
I started my thread with the knuckle rebuild. Right or wrong you get the idea.
So, we got as far as the out wheel bearing race and could not get it to seat. This morning we are going to cut a round piece of plywood that we can use to drive it evenly. So far, my son has made 5 attempts to get it in and it always gets uneven. That's the last race. Once that's done, we should be able to move steadily forward. And, yes, we kept the shims where they were.
The other thing we are struggling with is driving the steering knuckle into the trunnion bearing. Really not feeling comfortable about pounding on the 6 bolt knuckle and the knuckle house won't stay aligned while we're beating on it. I'm afraid of damaging the upper trunnion bearing.
I use a regular hammer on trunion races. You don't need to be that careful. I tap around the ring to seat it evenly. As far as the high steer arm, Sometimes putting the bottom cap on loosely will align the knuckle hole in the top better. You may have to tension the bottom cap while alining the top hole. The pressure on from the bottom studs will hold it in position while you tap the arm in.
Ya, we are doing that, and that worked great for the rear bearing. But the hub studs are in the way on the front and we are having a hard time driving with even pressure.
So, the outer race is refusing to go in. There's either an imperfection in the race or the hub and it wobbles when we try to put it in. I've used emery cloth on the hub, we've put the race in the freezer and used a torch on the hub and it won't go in easy.
Okay, got the race in. Had to put a stone on the die grinder and clean the inside of the hub. It's fu**ing tight in there. Now, onto the trunnion bearings. The video shows putting new studs in top and bottom. But, I only have the old studs. I'm hoping that will be okay.
Sometimes a deep socket that fits the size of the race can help get it started evenly.
Front axle rebuild. Fun project.
I'm glad the next one I do is from a pile of parts, loose and in crates and boxes. No goop everywhere to get things messy. My paper towel budget should be next to nothing. The axle will go into my '71 FJ40, finally. I sourced all of the required parts at least 18 years ago, including a bare axle housing from @wngrog IIRC - or was that Charles Kim?
