The way the timing chain port is offset, you can’t install a HG flipped wrongways.
The gasket chokes the coolant passages, but some of yours look clogged, so expect to flush the snot out of it with a few pure water fills (since you don’t freeze in FL, right?). -
Correct, no freezing in Florida
I used a gasket scraper on the block, but I have years of experience scraping pump cases from the refinery, so a freshly sharpened scraper for me is great + any brand of WD-40 type crap to lube what I’m scraping & soak the area I’m not working. -
Considering a gasket cleaner, hesitant as I don't want to scratch surface, etc.
Once clean, acetone wipe (or windex, 409, whatever you have) - you want the mating surface clean enough you would eat off. -
Acetone when finished is what I was thinking.
The texture you’ll prob find from old gasket wear in the block isn’t any biggie.
Just get it clean & slap a new HG, and fill/flush the coolant system a few times & then prob pull the radiator & flush it on the last water dump.
You probably have some good scale going in that water jacket & radiator.
