Just get a coolant pressure tester.. easiest way to look for leaks.
Pump up system to like 16 psi and let it sit.. if there is a leak you will see the psi drop. I'd leave the plugs out too just in case you fill a cylinder with coolant.
If that's good start it with the radiator cap removed and look for bubbles. Sometimes the exhaust will leak into the cooling system and you will see the bubbles.
