I went out and unplugged each of them, none are broken, all of them are clean, no frayed wires, etc. Plugged each one in with the anticipated click that they went on good..You had the lower plenum laying in the danger zone,double check all the plug ins and sensors that are on that side of the engine,make sure they are all plugged in and none are broken.
Injectors all plugged in? I had multiple broken injector plugs in the harness side. I replaced them with new and then when I plugged the new into the injector, the injector tab broke... They would seek loose and I would get misfires with no codes. Super glue works well..
You likely already tried this, but how does advancing the timing impact it? Also if you disconnect the exhaust before the cats relieving back pressure does that help?
It sounds a little bit like when a buddy of mine forgot to connect a vacuum line on his mazda. But you've already checked all that.
Mine ran that way last week after replacing distributor o ring. It took a couple of tries to get it right. Once I got it alligned properly it ran fine. Might be worth rechecking the timing if you haven't yet.
I've had vacuum keep the rpms down and make accelerating very doggy. You could could try spraying them with carb cleaner and see if it changes. Someone posted earlier this week doggy acceleration after hg job and that was because the cat was clogged from when the hg went.
Can't check timing as it won't come up to 2500 RPM per FSM. So I haven't checked it. TPS shows 75.3% at WOT. I took out the TPS this morning and it was a little gummed as you described, I cleaned it up and reinstalled. Was your idle as low as mine, around 500? It won't go higher than 500 no matter what I try.Didn't see it mentioned, but did you reset the timing with a timing gun after you got it idling?
Another thing to check is the throttle position sensor. Like yours, my truck sat for a year before I rebuilt the engine. I had a similar idle issue. Turns out my TPS was sticking. It tested fine according to the FSM but I took it apart and the grease on the inside was gummed up. After cleaning and fresh grease all was well.
Good luck!
So, just curious, how hard is it / how much time would it take, to remove the timing cover? I'm concerned that the timing chain dropped off the lower teeth, and...
Forums>80-Series Tech>
HELP! Engine won't start after head gasket R&R
Im sure you already read that thread but sounds like your symtons. I would think distrubuter but you have already adjusted several times.
I wish that I had a half-way easy way to tell if this was it. I guess the only way is to take off the front cover and oil pan at this point?
Yes mine was less than 400 initially. I tried to set timing with the light and realized I was off by 1 tooth on the dizzy. (Pretty easy to do). Once I had the dizzy corrected I still had idle issues until I cleaned the TPS.Can't check timing as it won't come up to 2500 RPM per FSM. So I haven't checked it. TPS shows 75.3% at WOT. I took out the TPS this morning and it was a little gummed as you described, I cleaned it up and reinstalled. Was your idle as low as mine, around 500? It won't go higher than 500 no matter what I try.
