Head Gasket shot. Committed
Thanks everyone for input, I really do appreciate it. Lots of great people always willing to lend an ear and give advice and opinions.
I am laying down the tools until after Christmas. I feel like I am close, but I always do. It’s always wait, let me just try this one last thing. But the wife and kids would probably like to see more of me so I am laying the Tools down for a few days.
Make sure all injectors are firing , can listen with mechanical ears, make sure the plugs alternate colors every other injector so you don’t have say plug for number 2 plugged in on injector number 3.
Check tps. And distributer inserted in correct position should be pointing at ccorrect position when crank and head are both tdc.
Make sure all engine grounds are bolted in seen those cause weird things.
Look over all vacuum lines including the plastic plug down below the intakes that has two hoses going to it, sorry forgot it’s correct name, but it threads into the block
I'm seriously not doing any more work on this for a few days.
But... So I took the distributor cap off after turning to TDC. Oddly, the center piece was pointing to about 1:30, almost 2 instead of 11.
I know how I made that mistake, I lined up the protrusion with the mark and installed it originally with the cap on, when I did, it rotated off of 11'oclock. I know better but that's what I did I'm certain. So it was off about 90 degrees but it ran and sputtered badly.
SO, I set it back to just before 11 and inserted it so that it would end up right at center of number 1, or 11'o'clock. Buttoned it all up and guess what? It wouldn't turn over, which tells me that I'm 180 degrees off now. So when I originally installed it I must have been 270 degrees off. I know what to do next, but I gotta stop, I'm going to be in trouble for working on this cruiser again.
It seems like it should still turn over just fine. Do you mean that it wont fire?
Ok, I honestly didn't touch my tools before this update.
At about 2:58 in the morning I was thinking to my self "self, you remember you were hurrying up trying to reseat the distributor, you found the easy way, remove the 3 screws, unplug, and seat accordingly. Well, remember you were excited that you did this without removing the battery box and you were excited that you could so quickly and nimbly take off the cover, especially that bottom screw. And then you put it back together paying special attention to that lower screw, and then you quickly and excitedly jumped in to start it up. And then you thought you were off 180 Degrees because it didn't start. Well, do you remember plugging in the top plug connector?"
So, I woke up, went out, plugged in the top connector and it started up just fine. :-)
Similar to the thread HELP! Engine won't start after head gasket R&R
I hurried, I hurried, and I was careless even when triple checking. I didn't want to get caught with a tool in my hand as I'm supposed to be celebrating Christmas, family, friends, all that good stuff.
I'm excited that it started up finally, now I just need to adjust the timing in a few days, (or at 2AM when nobody is looking).
Is it just me, or do others have to sneak in cruiser work too?
I recently replaced the crank case ventilation hoses on my E46 bmw (it's way more complicated than it should be) and once completed it would run, barely, and all of the lights on the dash were lit up (check engine, traction control, etc). I thought to myself wtf did I do.... Turns out the idle control valve was unplugged and so was the traction control plug. Same as you, it ran perfectly once plugged in.
I don't want to be the technical jargon police, but no one else is doing it so I guess it falls on me. If the engine isn't 'turning over' that means that nothing under the hood is moving when you use the starter. The engine's crankshaft is literally not turning. That's a lot different than not starting/firing, especially when troubleshooting, the terms do matter.
Once you have it idling again, you need to put a timing light on it. Sure it may not be FSM procedure and you won't be able to set at spec, but you should be able to see aprox how much timing you have very quickly. If you can't even see the timing mark on the crank pulley, you're way off. If it's in the ball park, it rules out distributor timing issues to some degree.
If the former doesn't yield results, you should double check the CAM timing by putting engine to TDC at the crank on #1 compression stroke and verify the alignment marks on the cam. The chain position and link location doesn't matter, it's the position of the crank relative to the CAM. If this alignment is off, you'll need to correct it. Relieve chain tensioner pressure and remove cam gear, move one link to align. Rotate the cam to align the CAM timing marks and re-install. DO NOT rotate then crankshaft during this procedure. You have to get the marks on the CAM and the keyway all lined up while the crankshaft and chain remains stationary. There is no need to remove the oil pump/timing cover. Honestly I'd be surprised if it ran at all with one link off though. If you do end up moving a link on the chain, turn the engine manually one full cycle after you are done (two revolutions of crank) and verify that it is in alignment after you reach TDC again. You'll want to recheck dizzy timing after this procedure as well of course.
Watching your video and looking at your pic in post 121, the ignition rotor was generally pointed at the #1 position on the distributor so it was at least pretty close and certainly not 180 out. A timing light check is still worth a shot though. However, if your cam gear alignment was off a tooth on the chain, that will not show up with the timing light. Were the cam gears two alignment marks lined up when you put the drive gear on the camshaft? Do you have a picture of this alignment?
Another basic troubleshooting procedure is to get out your can of starting fluid and give it a brief shot in the intake, then attempt to start. If it runs MUCH better for a few seconds then you are likely dealing with a fuel problem. If there is no change, or some nasty backfiring, you are back at some kind of timing issue.
A compression check can also be valuable in diagnosing a cam timing issue. The compression may be down across all cylinders if the valve timing is that far off.
The video you posted shows that it is much more than one injector not firing. You'll be able to drive a cruiser with one cylinder not firing. It will be rough but drive-able and not down on power too horribly much. Complete starvation of fuel to all cylinders could be going on, but that's the purpose of the starting fluid test, if it runs OK on starting fluid for a couple of seconds then something is preventing the gasoline from getting into the cylinders.
Thanks for the info but I posted that pic as a reference for he who started the thread and one other participant, not myself. This is not my thread. My 80 started and ran well upon completion of the HG job with the rotor at 11 O’clockish and the crank at tbc on compression stroke.
Thanks for the info but I posted that pic as a reference for he who started the thread and one other participant, not myself. Thus is not my thread. My 80 started and ran well upon completion of the HG job with the rotor at 11 O’clockish and the crank at tbc on compression stroke.
I missed the poster there. The pic is a good reference!
So, I woke up, went out, plugged in the top connector and it started up just fine. :)
top connector ???? you was able to start without the top connector?
Curious what others think on HG vs. full rebuild when the time comes. All of our trucks are at least 22 years old at this point and most have what the rest of the world would call "high miles." If/when my headgasket goes I think the extra expense of a full rebuild makes the most sense.
Thoughts?
Thoughts?
When my head gasket needs done I don't plan on a full engine rebuild. Full head rebuild, yes.
Thoughts?
The main issue is bottom end oil leaks. If you don't drive it with bad head gasket for a long time and don't cause other damage by doing so, then the rings and bearings are probably fine. That doesn't fix the lower end leaks that just can't be avoided due to age. To do just seals would be a pretty valid thing to do but it's almost as much work as a getting a fresh hone and throwing in some new rings and bearings, you are so far into it anyways.
Got the timing set today. Starts and runs great. Almost feels like more horsepower :-)
A little smoke on initial start, likely left over water in cats. It cleared up in under 5 minutes.
Put the ARB on tomorrow then get the indide cleaned up.
Thanks everyone for your help and input.
Got the timing set today. Starts and runs great. Almost feels like more horsepower :)
I bet it feels good, doesn't it?
You are in a rare club of people that can say that they know how to take apart the motor in their car and put it back together. I would be proud of that if I were you and well, me I guess. ;)
