Head Gasket shot. Committed
It does sound imposing to remove the entire engine but the amount of work, IMHO, is less than removing just the head.
The additional items you could do if you had the engine on the stand:
- both oil pan reseal (read my thread on upper oil pan arch seal)
- rear main seal
- transmission input seal
- comfortably remove the head/intake/exhaust manifolds
- you can remove the ECU harness with the engine and then carefully inspect and wrap the section around EGR that's known to melt wire insulation and cause running issues under load. IMHO, it's pretty easy to simply unplug the two mondo connectors at the ECU then pull it through the firewall. Leave it resting on top of the engine, then pull the harness+engine as one unit. Trust me when I say that it's easier to do this than to painstakingly unplug 20+ year old connector and NOT damage them. Once the engine is on the stand, you can carefully undo the connectors comfortably vs reaching over the engine bay. These connectors are old and crispy so the more attention you pay here, the happier you'll be in the long run.
- do the PHH, much easier when the engine is out
- on my second 80, I removed the head, had it decked and worked on. Turned out that the engine block surface needed to be resurfaced too so the short block came out as well. So, there *might* be a small chance that your block surface may need to be decked as well if you have porosity cracks that allows coolant to sneak into the combustion chamber. I found this out AFTER i put the head back on the engine and still had coolant loss. :bang:
-R/R the motor mounts
-timing cover seal
-timing chain check. R/R if it stretched
-timing chain slipper guides. These are made of plastic and wear down over time.
-Oil pump O ring and seal
- and whatever else you can think of "while your'e in there" :hillbilly:
I realize this list is huge but IMO, if you're digging into an engine of this vintage for just a HG, you're not doing yourself a favor in the long run. You can piece meal your way through the entire list over time as time and money allows. Assuming of course, you plan on keeping your 80 for the long haul.
Pics of my project How to get a diesel freak and an anti 1FZFE freak in the same place?
Some interesting points. I already have all of the connectors off, the pesky heater hose is already done. I am waiting for the cylinder head. At this point how much more do you think is left to pull the engine? I am tempted but haven’t done that in this lifetime.
The exhaust manifolds are already off.
If you pull the engine, you could do a complete re-seal job and be good to go for a long time.
Hood off with some help.
Pics 1-5 of head gasket
Pics 6-10
Pics 11-15
Pics 15-19
Pics 19-23
Pics 19-23
Pics 24-28
Pics 29-32
Pics 29-32
Pics 33-36
Pics 33-36
Pics 38 -41
Pics 42-45
Pics 46-49
Pics 50-54 done with pictures.
Worked with @stpetedale to get hood off and get the cylinder head off.
So, a bunch of pictures. Cylinder 6 doesn't look steam cleaned. Exhaust wasn't steam cleaned looking either.
The vehicle didn't overheat, I had gauge on it and it only got to 188 on the 30 mile ride. Never overheated while I had it. Perhaps PO? I did notice that there was a brand new valve cover gasket, the bolts were barely tight, maybe 10ftlb. Head gasket looks original to me.
I don't think I'm pulling the block, just don't see the need and don't really know what more is involved.
What are your thoughts on where it failed?
good time to delete the egr, you can fill in the egr port on the manifold with some mig weld and have it ground down flat. you can take a bank 1 gasket and make it work.
looks like cyl 1 where the discoloration on the piston is
