Build Goat. A 1967 survivor FJ-45 LWB
24 hours in a tank of Zepp Purple and everything came off with a swipe or two in the parts washer.
I’ll pressure wash it and it will get some fresh paint
The happiness is at the end when you see the finished product.
While working on stuff that is fighting back........i just keep telling myself I do this for fun.......i do this for fun
Gotta love being a car guy......lol
I’m going with your brake formula. Non ABS 80 master, JTO spacer and discs on all 4 corners. No prop valve.
My trust is in you. Only difference is the rear of the LPB is lighter.
Does your brake line kit maker need to know about these rear discs? Hmm?
Link to the kit I used
Things slow down when you get to the front.
One thing I always do is swap ends with the 3rd members. The fronts likely have less than 1% of the wear on them as fronts as they only turn while in 4WD.
RTV and no paper gasket. They suck no matter how clean you get the surfaces.
Metric Overland nuts. I reused my old washers. The ones they sent distorted when I tightened the nuts like i do...tight as hell.
All laid out and sorted with the instruction manual from
Scale via Kurt
I may or may not have used two different brands of #2 grease. I’ll make sure to let Mud know if my front end seizes up due to such neglect
Put your races in the freezer to shrink them up a bit to make them smack in easier.
ASCO pig hubs. Love rhem
Both ends are getting new pinion seal and flanges that are still on the way.
