FZJ80 Oil Choice? (April 2017)
  • Total voters
    115
dont forget the Nippon synthetic tranny oil enoes now thats good stuff i like it bettere then dealer probly the dealer supplier you can put it in any lexus or toyota transmmision ANY model! toyota oe coolant fliud auto houze tempe 18.00 a gallon with free shipping thats the aisin pink 4 gallons 1fze they are the oe supplier.
Care to translate?
nippon eneos oil for transmission. aisain oe coolant pink, auto houze tempe az 18.00 a gallon free shipping.
What is happening here!?
you can google nippon enoes oil its made in japan. 10 to 15 dollars a quart tranmmision fluid aka silk juice. the pink coolant toyota sales an lexus is made by aisain japan an imported in a silver 1 gallon bottle an sold under the toyota name for around 24.00 plus tax. in tempe az they sale it for 18.00 a gallon. an free shipping over 50.00 on line the 1fze takes 4 gallons. the place is called auto hous or simlar to that name with a z. amaqzon has the other oil much cheaper an to your door an free shipping. bearing grease use lucus heavy duty wheel bearing grease has highest water wash out all requiremnts for yota an highest temp same for u joints. axles 100% lucus oil adative dif 25% an 20% in engine. use castrol an valvoline they fulfill all car truck requirments. you can close your eyes with that no worries api sg etc. diesel oil doeseny have detergents for gas engines i think sf or sd you can google this also an most have zinc in them an destroy catltic converters. the aftermarket converts dont perform well or last like oe. i hope this info helps.
ohhh on sliders on brakes use qrc brake lube purple or 3m silcon BRAKE lube. dont use bearing grease antisieze etc yor going bind up sliders on calipers an replace the boots. the grease also swells the rubber. wer getting off oil subjecy i dont have alot of time. i put what is recmonded from a tech who knows. no doubts the others will be like yeahp yeahp
Rotella T5 15W-40 semi synthetic, helps on valve seal wear oil use. stopped most small leaks from lighter weight, drip to seeps.
diesel oil has been knowing to burn up the cats an doesnt have correct detergents warranty dont cover it at the dealer there known for zinc
I'll be honest Jay, reading your posts causes quite the headache. Are some of the keys on your keyboard broken....most in particular the "d" key?
I run Rotella T6 in everything from diesels to push movers. However I did have to run Rotella T in the 80 when it was still gas due to oil leaks. Like others have mentioned T6 will point out all your leaking seals real quick.
Pacific Northwest climate. Shell 15-40 diesel year round for the win!
I use mobil one, not because it is a magical elixir but because I am lazy and probably don't change my oil enough. The truck sits alot and does not get tons of miles so I figure I will use a better oil to compensate. I usually change it based on the color over time. Once it gets darker it gets changed.
5W-40 Lexus Full Synthetic API SM with OEM filter.
Changed every 10k Kilometers
Desert climate.
I run Mobil1 Full Synthetic High Mileage 5W 30, 10W 40, or a mix of each. Straight 5W 30 causes more oil spots on my driveway and there is more consumption while driving.
