gear oil is seeping out at the knuckle; probably time for a rebuild? Anyone have recommendations what seal kit to get (we already changed the wheel bearings when we put the disk brakes on)? Is there a source for hardened axle shafts for a 1/72 FJ40? Thanks in advance, Claudia
Got my rebuild kit from Kurt at Cruiseroutfitters. Cheapest price and had everything. Also Longfield makes the full Chromo set of inners and birfs. 600 bucks a set.
I'll third cruiseroutfitters. I got a set from them, seemed to be top quality, everything fit well and his prices were good. Stuff arrived in two days, not two weeks
DSRTRDR: gear oil is seeping out at the knuckle; probably time for a rebuild? ... (we already changed the wheel bearings when we put the disk brakes on)?
If your knuckles were not centered on the axle housings when the disc brake conversion was done, now's a good time to do it since everything will be torn down anyway. Your axle housing seals will last longer.
So what kind of prices did people pay for the rebuild kit from Kurt? Marlin Crawler was the cheapest one I saw at $89 or so, and it only took a couple days to ship too.
Does Kurt's kit include the metal half circles holding the felts to the knuckle? They aren't in his picture but usually they are in the same package as the rubber ring, felt and steel split ring.
I will have one on the way today from Kurt, if you don't need trunnion bearings $57 will take care of everything in the front knuckles. Great guy to work with. He will continue to get my money in the future.
the kit doesnt come with the half moon peices that hold the felt on you use your old ones, he will sell you new ones though pretty cheap, i had to buy some when i did mine
