So after 405,xxx miles and driving for more than a year with bad valve seals, my Cruiser ended up burning an exhaust valve
Pulled the head and the exhaust ports were pretty coked up, so I had the local machine shop replace all of the exhaust valves, seals, guides, etc. using all OEM parts courtesy of CDan
Finally got a chance to put it back in yesterday and on the final sweep of the torque sequence, I managed to pull the threads out of the block on one of the holes (F@CK!!)
When I had pulled out the original bolt from this particular hole, it was a little bent, but I didn't think much of it at the time since I was ordering all new OEM bolts anyways
I just figured being TTY bolts, it probably just got stretched out of shape
Each hole was thoroughly cleaned and chased by hand, so I figured I was good to go
Anyways, I pulled pulled the head, ordered another gasket and bolt set from CDan and I'm currently looking into thread repair options
Has anyone here done a time sert on their rig?
I called up Time Fastener yesterday since I didn't see a kit for the 1FZ bolt size on their product listing (I guess they don't see much of these) and had to feed one of their techs a bunch of measurements (thread depth, final depth, starting thread height, bore size, etc.)
Just wanted to know if anyone here has dealt with them and what size of insert they used
