Let me rephrase what I said re the transfer case and trans part. Since the are weighted on different sides I jacked them up using a trans jack on the transfer case and a floor jack for the trans in order to hold/move them so they stay level. I tried moving slow and yes, used a tape measure to check that the surfaces were w/i 1/4" of each other as I pushed the motor forward, checked with fingers that the shaft was aligned to move through the T/O bearing but it moved and hence, no luck getting it through. Once I get a new clip for the bearing that should help keep it on place. I am planning on repairing the e-brake/seal so the drive shaft to the rear needs to be unhooked. If I remove it, will this make it easier to align the output shaft ? Seems simple but as I am finding details matter...
TIA for the help on this .. cluster
