One piece.I'm finally getting close to snagging one of these DD units. Can we still use our factory bezels with the RTX or is the unit basically 1 piece?
Where did you place the DD plug in terminal ? Does it fit behind the cluster?OEM fuel sending unit for my 1978 works with DD.
Do you mean the control box? I placed it underneath the glove box - velcroed to the underside of that.Where did you place the DD plug in terminal ? Does it fit behind the cluster?
This is good advice. For me though, I rebuilt the 40 and I sealed it up good, so had no concerns here. I also have my ECU mounted under here (3FE) so the control box fit naturally next to it. I built an ABS cover for all of this so it looks nice and clean.Don't assume that the inside of an FJ40 is waterproof.
I had my Dakota brain box bolted under the glove box, but enough of the cowl sealing was gone that it got wet and quit working after about three years. Dakota fixed it and said "That's your last freebie," so I made a waterproof box for it in the same location.
And resealed my cowl.
If I had known it would turn out that way, I would have come up with a waterproof box in the engine bay so that the only thing to pass through the firewall would be the main cable to the cluster and 3 or 4 wires for the button and knob.
does it come with enough length to locate the terminal box this far away from the gauge?Just finished relocating the DD control module from behind the instrument cluster (where it was crowded and untidy) to the glove box (pocket), Made a custom shelf for the module and GPS unit to rest upon.
Yes.does it come with enough length to locate the terminal box this far away from the gauge?
Yes the control box, does DD provide enough wiring to get allow this easily vs being closer to the gauge cluster? do you have pics or videos of your install?Do you mean the control box? I placed it underneath the glove box - velcroed to the underside of that.
Sorry don’t have much. A couple pics on this post here:Yes the control box, does DD provide enough wiring to get allow this easily vs being closer to the gauge cluster? do you have pics or videos of your install?
