Sure looks silly without the windshield.
job - Texican has a write up here on ih8mud.
Are you having a new windshield cut? Or just someone installing it for you. To put in glass is a onejob - Texican has a write up here on ih8mud.
The truck looks fantastic!!![]()
What else? I still need to:
- wire up the fuel pump relay. [check]
- wire up the rear marker lights. [check]
- wire up/relay the driving lights. [wire run, relay mounted, need switch]
- wire up the CB [check] and install the antenna.
- wire up the front locker. [wire run, need switch]
- bend the shifter cuz it hits the center console.
Thanks guys. The way it's wired is:
Relay terminal 30: power from the fuse block, 25 amp circuit (about the only vacant wire left).
Relay terminal 87: to fuel pump.
Relay terminal 85: ground.
Relay terminal 86: 12v from the ECU.
The ECU triggers the relay, that way the pump doesn't run if the engine is not on. I have another idea for the cutoff switch, not off the relay. I like the rubber mount idea on the pump. Right now it's bolted to the frame, which probably makes it loud. Ash, I might have the truck done enough to bring to the meeting. I wouldn't mind finding out how many amps the pump pulls.
So much for that idea.
Was that roll cage *and* seat belts or roll cage *or* seat belts? If it's "or" I think I have some lap belts you can borrow to get it up Unser/Montano/Golf Course for a half dozen miles...
Are you planning on rolling the 40 between your house and Marc's? Besides the roll cage, was there some thing else that's preventing you from driving the beast?
