Crank nut removal
SW MB CA
Thought I would share the trick I used to get my crank nut off with the engine sitting in a cradle, and without an impact wrench. The rope is wrapped around the pulley 8 or 10 times then looped around a 2x6. The 2x6 is levered against the floor to hold the pulley/crank stationary once the slack is taken up. I'd say it took somewhere around 350 ft-lbs to break the nut loose. Oh yah, nut is 46mm.
Hope this helps someone down the road. :cheers:
better and easier way to do it if you have the starter connected. just put breaker bar on nut, make sure its braced the way the starter turns and hook up a battery for one second and booyachaka, free nut.
Nice work, but, um ... Don't ya think it's time to invest in an impact? I'll put the first $5 (US) toward the fund... :D
let me guess ? your a carpenter by trade.... nice enginering
that's presidentially amended!
nice, but an impact is nicer.
Well, I'm happy enough with it, and the nut's off. Being a grad student (geology) I have to be a bit cheap on how I do things. Next up, how to get the block on the engine stand without a hoist. :grinpimp:
That's the kind of Ingenuity that will get you out of the @#$% some day.
The mind is most handy tool if you keep it sharpened.
A Major reason I come on this site is to see this sort of stuff.
Thanks, RockDoc, keep them coming.
