Carb troubles.
@65swb45 @thebigredrocker I found a spring to replace the missing one. no change.
@DSRTRDR ill definitely use those videos when I can. I don't have the time at the moment to tear into my cab myself. im in the middle of a move and job change. will be moving to Tucson. im hoping I can drive the cruiser down when I go.
who rebuilds carbs? any recommendations? anyone in AZ?
one shop that performed a carb rebuild for me several years ago is Auto Tech in Mesa, 260 S Alma School Rd Ste 135, Mesa, AZ 85210; (480) 464-1283. The owner, Randy Eckler, is an old school car guy, and they have the equipment to test whether it would pass emissions. I supplied the appropriate carb rebuild kit to him (bought from Cruiseroutfitters @cruiseroutfit).
But since your carb seems to be missing pieces, it might be better to send it to Jim Chenoweth here on MUD for a full rebuild (@FJ40Jim).
:rolleyes:
You could also send your carb to (65swb45) Mark's Off Road in Burbank, CA. I believe his turn around time on rebuilds is pretty fast.
Best to phone him.
Note his tag line above.
ive sent it to mark. when I tore it out I found I found a bunch or things on the drivers side didn't even move and the barrel had gunk in it preventing the drivers butterfly valve from moving... and the passenger butterfly valve looked wedged open a bit. im surprised I could daily it for so long!
it'll be a night and day differance after Mark works his magic
Now. Gasket question. When I took mine off the gasket at the carb base had 2 holes. But when I look at auto zone or Napa it just has the one lone hole. Would that work? Or would I need a specific gasket??
:rolleyes:
Both gaskets good in stock. Can ship with the carb.
And note: these are the same material as OE, not Kevlar like some other vendors are offering.
Well, installed the loaner carburetor from @GA Architect . Found mounting gaskets from cruiser outfitters. Hooked everything up and now it just goes brap brap brap and everything shakes. And everything smells like gas. 😕hmmmm im looking to make sure I didn’t miss anything, but it looks good so far.
