I'm down.
Once I finish everything off and put in some miles happy to take everyone out for a test ride.I can make hot dogs and cotton candy
I think I read min 2400lb clamping force. Definitely not designed to be activated while vehicle is in motionThat EPB is tiny, but I bet it has more holding power the stock parking brake...
Maybe, but so does a bread bag clip.That EPB is tiny, but I bet it has more holding power the stock parking brake...
I'll confirm this week after cycling the suspension without the springs on. 1.75" is me playing it quite safe. If its a concern for some, I could add another 15 degrees of rotation so caliper sits further away at 195 degrees from main caliper.Is there going to be an interference problem on the rear without 2” lift? Will I be able to utilize full travel? I was not aware of this and I have already ordered. I am keeping stock suspension height.
Been out with the flu for the past week, and first day back on this.
One issue with the rear lines was how close the 90 degree bend was to the shocks. Because Wilwood uses 1/8 npt on their calipers I've always disliked using 90 degree fittings and much prefer a 1/8 npt to AN adapter and use a swivel fitting on the line itself.
Unfortunately this causes a lot of stack height.
For a few days I went back and forth discussing with Hel Performance on solutions. In the end we agreed resorting to 90 degree 1/8 NPT to AN adapter was simplest solution. Sorry for camera missing focus...
I've gone back and forth and disassembled and reassembled the front and rear hubs more times than I care to count. But only thing left is to flush the brake fluid and wire the EPB. Ideally most should install the control module under passenger seat, but I've got one of my 3 amps and DSP controller under there and my AC unit for non-working center console fridge under my driver seat. Will likely just mount to where parking brake lever currently sits. Hopefully get to bedding in the pads this weekend.
Keep upAs I seem to be bad at what updates are shared where here's the brake line mount I came up with since this exists on the factory brake adapter/backing plate. Opted to go stainless.
Bonus:
This project wasn't without it's trials and tribulations.
What I thought she could take in the rear vs what could actually fit...
FNSL (top)
Aero DM (bottom)
Just a friendly suggestion, go with a more standard font. This one is damn near impossible to read. I wouldn't use it for anything, including your logo.www.maysiswerks.com Website soft launched
