Glad the videos helped! One day I'll edit the 6 or 7 into one long video.
The only variable is temperature. Most times the OAT is between 68F and 90F. If OAT gets to low, say 45F. The grease will thicken. This increases reading on spring scale. So I always try to have hub and bearings above 65F.
Do you also loosen the adjusting nut and torque to 38-57in-lbf (steps c and d) after torquing it to whatever it takes?Torque spec on adjusting nut, is whatever it takes!
), the hub nuts have a habit of wanting to unscrew themselves, so make sure that both of the washers are in perfect condition and especially that the inner lock washer's tab is solid and protrudes well into the groove.I go to 47ft lbs first, spin rotor forward a few turns, loosen adjusting nut, spin rotor forward a few turns, then retorque starting around 25ftlbs, check with fish scale take reading, back off adjusting nut spin rotor forward a few turns, then retorque increasing torque in 5ft lb increments repeating the loosen and tighten process each time until I work my way up to my target break away preload.
I found that the repeated loosening (unloading) bearing and re-torquing incrementally higher that I could achieve my target break away (13-15lbf) closer to 50-55ft lbs. it’s labor intensive but it worked for me.
150F hub temp seems high. I've had as much as 80ft-lbf on adjusting nut to get ~13lb breakaway preload. I get about ~115F w/IR gun on hubs. The hubs and wheel bearings can handle 150F, but still running hot for some reason!TL;DR: did a ton of work, repacked wheel bearings and torqued lock nut to 70ft.lbs to get 10lb on the fish scale. IR gun temps showed 150F or so on the hub/rotor after a 40 mile round trip. Steering felt much more precise, but is my hub / rotor temp too high? It was also, of course, hot to the touch when just touching the hub part.
I'm posting this in a few threads potentially, trying to find the best place to "keep the conversation" going about adjusting nut torque.
This past weekend I replaced my rotors and pads front and rear. I used Hawk LTS pads and Toyota OEM rotors. Truck has 260k miles on it and the service history shows wheel bearings replaced at 136k miles by Wilde Lexus Sarasota, then wheel bearings repacked at 164k miles due to "large amounts of play". Well, Wilde Lexus Sarasota employs a couple of super-hack-ass technicians who clearly used a punch to remove and install the adjusting nut and locknuts, but they didn't bother with the washer locking tabs, nor did they bother to do much beyond finger tighten the adjusting nut or locknut. Furthermore, those dirtbag techs cross threaded two bolts on the driver side rotor to hub bolts, and then decided to use their air powered torque gun to run in 13mm bolts to fix their cross threading issue.
As a former technician ,that worked flat rate for a different brand (starts with a Por and ends with sche) and cared about my work, this is so unacceptable I am thinking of leaving a Yelp review and a google review with this information to see what happens. This is always my experience when baselining a new-to-me vehicle, dealer techs are hacks. I have never had a @2001LC experience where the tech took their time to do things correctly or to my standards.
OK, now that is off my chest, here's my situation:
As stated, I replaced pads, rotors, repacked wheel bearings, fixed the hub hack job, amongst other bushing replacements. This is part of a major baseline involving AHC globes, upper shock cushions, lower shock bushings, sway bar bushings, t-belt, radiator, all heater hoses and oil cooler hoses, clamps, etc. I take my rigs into Death Valley, sometimes 4-6 hours away from cell service and the last thing I want is to be broken down and turn into the next German hikers from Butte Valley / Mengel pass media story.
When torqueing down the adjusting nut, I ended up at 70ft.lbs. to get 10 lbs on the fish scale, then it bumped up to ~10.5lbs when torqueing down the lock nut. I did not want to go higher than 70ft.lb on the adjusting nut...but even at 80 ft. lbs I still got 10lbs on the fish scale. Some of you have gone that high but reported ambient temps on the hubs. I followed most everything I could learn about using the fish scale multiple times and averaging the result. I used Mobil 1 grease, the red grease and repacked bearings using the new Lisle bearing repacker, and used the entire tub so I could fill in all the cavity volume of the hub.
After a 40 mile round trip today I used my heat gun to check the hub temps and they were hot to the touch and the hottest points were 150F after getting off the highway and into my driveway - about a mile with a few stops along the way.
So, long way to get to my question, are my temps too high and are my wheel bearings too tight?
Yeah I leave the hub caps off. I shoot near grease cap at few points between grease cap and nuts/studs/cone washer of hub flange. The brake rotors gets so hot, they melt plastic (killed my plastic caliper). They heat will transfer to the wheel hubs. So don't over-brake, using your transmission gearing down to help slow is one way to avoid overheating brakes.Thank you for the reply. It just occurred to me to ask when taking temperature do you measure the front axle drive flange? I put Tundra TRD Pro BBS forged rims on and didn’t leave off front center cap to IR gun the axle drive flange.
I was measuring the temp Inside the wheel where hub meets rotor hat. So potentially mainly measuring rotor heat from braking.
Edit I should also mention I used fish scale as you describe. Basically I followed all of your extremely helpful videos and messages on wheel bearing and hub repair processes.
Pass side is packed a little more full than driver to see if any variation.
