Advice Please
Arizona
Hey all, will appreciate an assist with a couple of questions.
I have a 78 FJ40 in the shop. Working with a great guy who is semi retired (father of a respected father/son shop) and very experienced. Think mine are the first FJ's he has had in his hands (two 78's, one already up and running well). He has just begun giving it a compete review can likely sort this out but asked if I could check a couple of questions that might save some time.
Hope my notes are correct, please let me know if any question asked seems incorrect.
What type of fluid is recommended for an FJ transfer case?
What oil is recommended for the trunnion in the front axel, the joint housing?
He was perplexed when opening the filler plug for the transmission and fluid poured out (over filled) while the transfer case was near empty. Wondering if its possible the transfer case is somehow migrating fluid into the transmission.
Thanks for taking a look.
80-90wt gear oil for differentials, transmission, transfer.
Looks like you have a compromised seal between transmission and transfer. Common. Put new seals if you are taking transmission and tranny out for work. If not some do a hose connecting the fill plugs on tranny and transfer. Search it hear on Mud.
Thank you!
Promise I am not being lazy as we need no work for the transmission and think the work around idea is best for this circumstance... but not successful so far with searching for it on Mud. Any search term suggestions will be appreciated?
Try "bypass hose." SOR sells them, also, @shipmag might be currently offering them. Pretty standard modification, as all the parts which might be related to the seal are not available new. Be aware that basically all the seals on my transmission and transfer were brittle upon partial overhaul; yours might likely be the same.
Try transfer case bypass hose. It is a band aid only. Fresh seals are the solution. Keeping a regular eye on the tranny and TC levels is the best preventive. I believe they both call for straight 90W gear oil. The straight weight 90W is hard to find, Most are blends. I run 85-90W
Make sure u install / or Make sure the Mechanic Installs ALL NEW OEM TOYOTA Gear Box & Axles Service Plugs Crush Rings Gaskets
Make sure The Magnetic Plug Is on The Bottom Drain Location .......................
I Recommend FULL Synthetic Gear Oil as well ( IMO )
its Simple to Remember :
- The Aluminum Gasket
90430-18008 goes on your Aluminum transfer case
- The Steel Crush ring
12157-10010 gaskets go on all your Steel Boxes & axles
2008725
2008726
FSM says GL4 for the Transmission. I believe many run GL5 synthetic though.
GL5 is specifically better EP gear tooth lubricant. Since the T-case and diffs have large gears that are always under load, they need GL5. The transmission has no gear load in 4th gear, so vegetable oil would prolly suffice in there on the highway.
I keed, I keed.
GL4 is specified for the trans because it has brass synchro rings. I've never actually seen any accelerated wear of HD brass syncro rings due to GL5 usage. Yes, GL5 is unkind to wimpy little syncro rings in T5 trannies or subaru boxes, but Cruisers seem to be too big & stoopid to care.
All of this is in Qrts
Engine
8.4 With Filter Change
7.4 Without Filter Change
90 W
3.3 H42 Transmission
2.6 T-case
2.6 Front Diff
2.6 rear Diff
Cooling system
8.9 gallons capacity
Thank you
Thanks!
GL5 and yellow metals do not mix well.
Your front axle inner seals are worn so the gear oil mixed with the knuckle grease.
Have that all cleaned out and have new seals installed, 80-90w in the axle and some good moly lube grease in the knuckles and birfs. It’s great grease for the wheel bearings too.
Have that all cleaned out and have new seals installed, 80-90w in the axle and some good moly lube grease in the knuckles.
For the inner axle seals go with the Marlin Crawler seals:
