Accelerator pedal issue
Ecuador
Does the location of all accelerator pedals make it extremely difficult to use? For mine, i have to almost touch my shin with my toes or hold my foot up in the air. It's extremely uncomfortable and my leg gets really tired after 1/2 hr. If that's the way it is, has anybody tried anything to make it comfortable to drive?
Alright. I'll post pictures and dimensions tomorrow. Haven't heard of the seat extension mod but it sounds absolutely awesome.
Here are a couple pics. from floor to pedal is about 7" or so.
Does the clutch pedal seem high on yours ? Mine is so high I can’t really even rest the heal of my foot I kinda have to hover over it
It does seem high. When you're in rough country not having your foot solidly placed makes for some embarrassing accels and decels
Nothing the hot end of a torch won’t fix. Mine is bent to suit me, just be sure you have enough travel for the carb.
I had the same problem in my '74 FJ40, so I bought a '74 FJ55. Much better. Problem solved.
Seat extension. I had these same issues. If you are 6ft, you owe yourself this purchase. I couldn't even wear boots, because I couldn't bend my ankle that much. 2 inches doesn't seem like much, but it made a world of difference.
Your accelerator pedal looks to be way too far off the floor to me. I just went outside to measure......My gas pedal has 5" of travel to hit the floor. It has full throttle opening range. It is comfortable for long trips. You might try adjusting the linkage all the way to the carb to see if you can get it down.
I have much more trouble lifting my left foot high enough to work the clutch pedal. My clutch has 9" of travel to hit the floor which seems excessive.
If you lower the gas pedal height by bending the arm, be sure that you still have full throttle opening when you floor it. The last thing an FJ40 needs is a throttle that doesn't open to 100%.
