I think the 4.7 would be ok in a 60 series not so much in an 80 series.Well the 4.7 is a nice engine and very smooth. It wont be the fastest v8 swap but will drive really nice hopefully and have adequate power.
I have no idea what the dollar per gained hp ratio is over stock for the 2uz swap compared to the LS swap cost.I think the 4.7 would be ok in a 60 series not so much in an 80 series.
2UZ makes about 230HP without VVTi or about 270 with. Iron block and aluminum heads, heavy motor.I have no idea what the dollar per gained hp ratio is over stock for the 2uz swap compared to the LS swap cost.
Don't forget the abundance amount of aftermarket parts and availability of parts almost everywhere for the gm powerplant .2UZ makes about 230HP without VVTi or about 270 with. Iron block and aluminum heads, heavy motor.
There's more variants of LS motors than you can shake a stick at, but most of them make more than 275HP. Lots to choose from with aluminum blocks, too. I put an aluminum L83 in my 80 and will probably have to pull spacers out of the front as a result.
Main reason I did the swap. I was tired of waiting days for parts or going to Toyota dealer and spending stupid prices on parts for the 1fz.Don't forget the abundance amount of aftermarket parts and availability of parts almost everywhere for the gm powerplant .
So you're just doing this for fun lolA/C comp is the same story. Looking like the 100 series is the way to go with it's more universal manifold style which gives WAYYYYY more clearance, like, ACTUAL room to work with. I'm thinking maybe an early SC400 compressor would be an option as well as they have a similar manifold.
100 series compressor (with shipping manifold plate for mock)
View attachment 4058671View attachment 4058672
And here's the Sequoia compressor. Literally the worst possible choice here as it puts the lines right into the steering box, and it's getting tossed on marketplace since it blows snow lol
View attachment 4058674View attachment 4058675
Looking at the manifold on the 1fz, I believe it will put the lines at the perfect angle with clearance and accessibility for adapters for ORB fittings. If not, I have a stack of Denso manifolds I've collected over the years from various things for this exact purpose that will get me where I need to be
No, I’m doing this because I’m retarded.So you're just doing this for fun lol
These swaps are great in theory, but absolutely stupid in practice. They just don’t package well, AT ALL. I mean, if you got t boned in a 100, and got a cheap roller 80 and can fab and roll the rest of the payout into the project, as well as have the room and time, and stupid emotional attachment to the wrecked 100, then yeah man, I get it! Anything outside of that scenario, this is a dumb swap.I was wondering why you were doing this swap. At least you're honest..
Holy s*** lots of good content, Where did the purple people eater come from. I have the vortex maf coupler but I forgot about the fact my non VVTI maf is the older round base vs the blade style.
So @WrongsideDaily I have a quick question. Is the blade style maf for a 2003+ 100 one of those occasions where it reads the same as the 98-02 verity? As I am having a hard time sourcing something like the “purple people eater “.
The question is posed as if one is a non cruiser owner and the answer for that person is simple; Import a 105, and LS swap that.It begs the question if it is better/easier to SAS a 100 or 2uz swap an 80...
I'm sure we would get different answers in the other part of this forum..
Well I wonder why I haven’t seen that on their site or that it hasn’t been mentioned to me as they have my ecu and harness right now doing all the wireing now.View attachment 4058811
They advertise on here. If you get one, maybe have em test fit a MAF in yours, or change their file so it fits properly. And please have better taste than purple. The fact that they even offer such a tasteless color has me sus AF about the whole operation. Can’t get the screw in when the part is square into the recessed notch. Can get the screw in and it *may* seal, but it won’t seat. You could just notch it yourself to get it to seat, but paying for something that doesn’t fit as advertised kinda pisses me off. Especially something as simple to QC as this. Plus I’m already angry about the effing purple.
Doing a harness for UZ into 80? Man, I’m REALLY curious to see how that works out for you. The 80 series layout is pretty weird. Hope you’re using a 100 series ECU, losing the pwr/2nd gear start functions kinda suck, plus some of the other little nuisances.Well I wonder why I haven’t seen that on their site or that it hasn’t been mentioned to me as they have my ecu and harness right now doing all the wireing now.
Thanks for the quick response!!
powertrain out of a early 02 100 series, useing the 100 A343F trans and the 80 Tcase and oem log style exhaust manifolds. Useing the 100 series ECM with a little reflashing to make things a little more stright forward. Off the shelf motor mounts form Toyonly swaps, slee belly/rear crossmember and hodgepoging things togeather as I go. So your info the last couple of days has been refreshing that I am mostly on the right track, my PS pump for instance is out of a GX so the gravity line points to the air box but not at the headers at least lol.Doing a harness for UZ into 80? Man, I’m REALLY curious to see how that works out for you. The 80 series layout is pretty weird. Hope you’re using a 100 series ECU, losing the pwr/2nd gear start functions kinda suck, plus some of the other little nuisances.
It should be on their site unless it was taken down. Again, I didn’t order from them or choose them as I have someone else I use for ECU programming and I do my own harnesses, this is just what was given to me.
So glad I went the LS route. LolNo, I’m doing this because I’m retarded.
EDIT: This thing is getting a hot air intake or the sequoia box I saved, I’m not wasting the time to modify the can to be shorter to use the stupid purple maf housing
Anyhow, the purple people eater is going to get put into use. I was hoping to be able to use the FZJ maf since the volume inside it was pretty ballpark looking from the engine side and the displacement is ball park. I’ve come across instances where you can use a completely different maf, but it reads properly… this isn’t one of those instances. I repinned my 100 to accept the 80 series maf and while it threw zero codes, it ran rough due to richness. Added a little foam and the housing fits snug, I’ll figure out a sandwiching trim ring. Would be cool if they printed a housing with threaded bossesView attachment 4058737
View attachment 4058738View attachment 4058739
The dude that owns this tried to call Slee about the trans mount when I told him that it wasn’t just slot the cross member like he read it was and they told him NOPEpowertrain out of a early 02 100 series, useing the 100 A343F trans and the 80 Tcase and oem log style exhaust manifolds. Useing the 100 series ECM with a little reflashing to make things a little more stright forward. Off the shelf motor mounts form Toyonly swaps, slee belly/rear crossmember and hodgepoging things togeather as I go. So your info the last couple of days has been refreshing that I am mostly on the right track, my PS pump for instance is out of a GX so the gravity line points to the air box but not at the headers at least lol.
I guess I just missed that part of thier website, I saw all the wireing stuff. I am not a fool but wireing is not a strong suit of mine nor do I have the time or a wife that would tollerate a "dirty ass truck parts" / wireing harness and 2 trucks worth of printed out wireing digrams scattered all over the living room floor for a month or so. Tim at LexusV8 has been very helpful, and so far has done a good job no complaints as of yet, but obviously its not running yet lol.
I need to put build thread togeather.
