Intermediates are front 170/260 & rear 170/270
HD rear is 170/320
how heavy is your rig? where is the weight? i strongly suggest you drive someone's rig that's setup like yours and has the suspension you want first. i wish i had. depending on how your weight is setup, you may have to do the expensive shocks. i did the stage one on my 7k rig with a lot of roof weight and it was sketchy. i've had two people tell me that i needed to do the stage 4 (which i also can not afford, so the slinky is on the garage floor now). it makes sense...a non adjustable shock is going to be set up for a common rig, my rig is not common. it seems like those that are stupid heavy and loving it are on stage four. i'm back on my buckboard shocks and springs, but at least i feel a bit safer at 90mph
@dec505 i wouldn't recommend it.
Try using the Slinky coils with old shocks.how heavy is your rig? where is the weight? i strongly suggest you drive someone's rig that's setup like yours and has the suspension you want first. i wish i had. depending on how your weight is setup, you may have to do the expensive shocks. i did the stage one on my 7k rig with a lot of roof weight and it was sketchy. i've had two people tell me that i needed to do the stage 4 (which i also can not afford, so the slinky is on the garage floor now). it makes sense...a non adjustable shock is going to be set up for a common rig, my rig is not common. it seems like those that are stupid heavy and loving it are on stage four. i'm back on my buckboard shocks and springs, but at least i feel a bit safer at 90mph
I'm still running my rear Ls with my Slinkies & it's works just fine, but at 7K you should of got the HD rears.
Lots of springs are made by the same manufacturer but that says absolutely nothing about them being the same thing. People think the same thing about roof top tents and it’s false. The Slinkies use a unique mfg process that the manufacturer doesn’t even use on their own version of dual rate coils. Not all springs are the same.7k? I would run the slinkies if they sold just the springs, but they don't and purchasing these things seems ridiculously hard. I plan to eventually go with the tourflex springs from trail tailor. My understanding is alot of these springs are made by the same mfg and sold under different names. I figure for $600 or so if I can try some better springs it should help the overall suspension while not breaking the bank.
i do supposedly have the heavies. i'll try them with the ome shocks and see how that feels. the slinkys are definitely a smoother ride than my old slees. i may as well at least try it, but it will have to wait after i get my cortisone shot in my shoulder. i can't run it with the shocks i have and i can't see plunking down for shocks that would make my suspension worth more than my rig cost, especially when there's no guarantee i'll be happy (which i've been with my fox shocks and the current slinky setup)Try using the Slinky coils with old shocks.
As for mixing shocks... understand not everyone wants to drop the cash for the top tier Slinky kits and feel like they will be fine with the xyz shocks they have. It can work but is going to have a number of performance shortcomings. A lot will depend on how you use the truck. Heavy trucks will amplify the shortcomings of more basic shocks.
If you want the travel available from the Slinkys, you won’t get it with other shocks unless you go custom length or different shock mounting or both. The Slinky shocks are built to Darren’s specs for length and valving to maximize available flex and performance. L shocks are too short. In my opinion after years of running OME suspension the L shocks are too short for the OME kits too.
We have mentioned before that the product testing trip we did in the spring had a handful of trucks either with L shocks or RS9000s. By about 1:00 in the afternoon each day of that trip the non-Slinky equipped trucks had lost almost all shock dampening and the trucks would pogostick down the roads. We were traveling at good speeds but I wouldn’t say it was “fast”. The shock oil in the other shocks was just getting too hot and couldn’t handle the longer stretches at speeds as well. The solution is better shocks or slower speeds and/or shorter distances.
I think the differences are obvious: red, yellow, blue, black, or silver.Understand completely. I am sure there are differences. What those are I don't know specifically. It seems a grey area in both the RTT and the spring world. IMO, in the RTT area the direct chinese tents suit my needs fine. I have owned 2 of them and they have worked and were alot less than buying from a vendor, about half the cost IIRC. For me that makes more sense, but I know I am a cheap SOB. I also ended up selling both tents for what I had into them, which was important to me to not lose money. I understand that of course you will defend the branded tents all day long as you sell them and have a vested interest. It really just depends what what your budget constraints and needs are. I have yet to inspect other vendors tents such as tepui in person so can't give opinions on quality.
As for the spring world it looks like dobinsons, trail tailor and slinky all have "slinky" type springs. So what specifically is the difference between all 3 of them? Please give more information on this "unique manufacturing process"? If this has been discussed prior I apologize. Just curious what makes the slinky springs so much better than other vendors slinky type of springs. Seems that they also sell tapered coil type of springs as well. Shocks I understand that the quality is widely different than the L shocks. Lastly, what is your vested interest in the slinky suspension specifically? I think this is a relevant question when looking at opinions of different mfg's on the web. I always like to know why a person is promoting a specific vendor and if they have been "gifted" or have some other vested interest in the end product. Non biased opinions are always IMO the best ones.
Sorry for the slow response. Been racing/chasing and driving home from Baja with very spotty service.Understand completely. I am sure there are differences. What those are I don't know specifically. It seems a grey area in both the RTT and the spring world. IMO, in the RTT area the direct chinese tents suit my needs fine. I have owned 2 of them and they have worked and were alot less than buying from a vendor, about half the cost IIRC. For me that makes more sense, but I know I am a cheap SOB. I also ended up selling both tents for what I had into them, which was important to me to not lose money. I understand that of course you will defend the branded tents all day long as you sell them and have a vested interest. It really just depends what what your budget constraints and needs are. I have yet to inspect other vendors tents such as tepui in person so can't give opinions on quality.
I apologize ahead of time if I am coming across rudely but I think the above are fair questions for those looking to spend their hard earned money wisely.
got the slinkies changed back on with the ome shocks. it's been a long time since i've been comfortable at speed, but i drove to moab with none of the rocking or concrete bucking that i was experiencing with the slinky shocks. i have not had time to adjust the suspension to match the lower height of the slinky (my pinion is pointed at an angle that makes me hope i don't toast the bearing) and the sway bar is half held on and it's still 100x better than with the slinky icon shocks. i am comparing the slinky springs to a very old (8 year old) slee 4" non progressive springs, both with and without the slinky shocks. supposedly, slee makes a progressive spring now. whether or not that's true and how they ride i can't comment, nor can i comment on any one else's progressive springs.
i can say that no way would i recommend the slinky stage one if you have a heavy rig (fat bastard is just over 7k). their stage one shocks can not handle the weight. say what you will about the ome shocks not working with slinky springs, they work a heck of a lot better than slinkys shocks. maybe i don't get the ideal performance out of the springs, but i get far better performance than i would if they were sitting in the corner of my garage pissing me off. i know adam loves his, but he also has stage 4. so does woody, so does justin. i respect them, but the salesmen get the best of the best to sell the product. those of us that have to pay get what we can afford.
if you have a heavy rig and are set on slinkys, either plunk down the cost of your car for stage 4, or find different shocks that can handle the weight.
Thanks for the update Ige. My truck is pretty heavy but not as heavy as yours. I’m a hair shy of 7k lbs. I had the Stage1 shocks for a year with no complaints. I was running both swaybars. I never had the strange behavior you experienced. what you have found is good info that has been mentioned before but good to point out again. The Stage4 is definitely a better choice for a really heavy truck. From your experience and mine, maybe 7k lbs is the threshold.got the slinkies changed back on with the ome shocks. it's been a long time since i've been comfortable at speed, but i drove to moab with none of the rocking or concrete bucking that i was experiencing with the slinky shocks. i have not had time to adjust the suspension to match the lower height of the slinky (my pinion is pointed at an angle that makes me hope i don't toast the bearing) and the sway bar is half held on and it's still 100x better than with the slinky icon shocks. i am comparing the slinky springs to a very old (8 year old) slee 4" non progressive springs, both with and without the slinky shocks. supposedly, slee makes a progressive spring now. whether or not that's true and how they ride i can't comment, nor can i comment on any one else's progressive springs.
Does the 80 have a speed limiter?
