icon USA has 2.0 an 2.5 with resvoir autcraft has 2.0 an resvoir also redline said they can do with out ccv also. The difference is the rod an houseing im not sure about internals or what assmbly was used icon USA said autocraft au resevres the rights to there shocks , which i respect an they can keep at the price i was quoted 3100 but i wil take them springs. Icon USA said for addtinal 100 they can make shock for me based off 80 seris 2.5 with resvoir. auto crafts shocks are made in USA i was wondering if they payed the extra 100 or send them to austrailia an ship them back. Thats why i called i didn't want to be sending shocks to au an imagine if they went serived right which i have had happen 2xs here in phoenix an Cali. icon is the best if you ask me tires an shocks are your life line in this game. i can go with out the rest like under wear an a under t or even socks but im not sporting flip flops i will pay not over pay. we need that nich that fit comfort an a LIGHT hit on the wallet. we need them springs an price fix and detailed info. the springss are in Australia an made somewhere if made here maybe cheaper for darren. Icon USA should sale darrens autocraft stuff to all its venders an give him royalty's but who am to say that darrens private deal an not are businessAre the slinky's a 2.5 shock? Icon's website says their shocks for the 80 are 2.0's. I may have finally found the difference between the two!
And I agree, for consumers, it's the price that's turning folks away. When compared with 4WU 3 link kit, you start wondering what you're getting for your investment. If money was no issue, well a lot of things could be done and said. But like everyone else, I'm on a budget with a goal in mind. I love the slinky reviews, but cost is definitely a deterrent!
not even close. according to the website, the 3link builder kit is $1935, but only includes brackets hardware and links. no bumpstop stuff, no coilovers, no brake lines, no sway bar extensions, no shop supplies for cutting/grinding/welding. and no labor for the folks that don't have the ability to do the install. the 50mm intermediate slinky kit comes complete, springs, shocks, brakelines, extended bumpstops, swaybar extensions for $40 more than the 4wu cheap kit.
The stage 4 slinky kit is considerably more than the top of the line 4WU kit. Also, the base line stage one kit has options that would need to be purchased, i.e. Caster correction, panhard, which makes the pricing on the two methods of long travel comparable.
Yes the 4WU requires welding, it also allows significantly more movement of the front axel.
When viewed from a dollars spent per the actual increase in front axle articulation perspective, a three link, even the 4WU kit, can't be touched by the products that are the focus of this thread. Spend $100 to go 1/4 of the way or spend $150 to go all the way is how I see this.Last time I checked the 4wu kit was by no means comprehensive or complete. A lot of things need to be added to make it whole. On top of that you need to get everything aligned near perfect and welded in. Its considerably more work and at least as much if not quite a bit more money than any kit you can purchase. If the Slinky coils are more than you want to spend ( and there's nothing wrong with that ) there are a lot of other options either recently on the market, or coming this year.
I went with OME Js because of all the delays and trouble people had getting the right product. Like I mentioned in a post before, I would rather give my money to a vendor who can keep stock on their shelves. If these guys are the exclusive dealer then they should have done better to keep them in stock.
If they get to that point in the future, then maybe I will get a set. Till then the OMEs will do great for sitting in trafficin LA
Will most who run a "long travel" spring and shock combination ever realize a real world difference with a vehicle like the 80 series? With suspension links and bushings like the 80 series? Will oem bushings be over flexed into an early demise?
Soaking up the bumps better is always a welcome trait but I'm not so sure any of us will benefit from more suspension travel than has long been available to us.
Take H1's for example. They are large and heavy yet very capable but not due to incredible suspension travel, rather, ground clearance through design and tire size and traction. One tire in the air isn't so bad when you have lockers.
I'm not advocating stiff, low travel suspension or discouraging whatever it is you want to accomplish with your rig. I run Rubicon more than any other trail,perhaps 4 times a year, and I havn't really wanted for anything to be honest.
I think @ericb1 makes a good point about the cost of the slinky/icon set up vs. what the 80 was designed to do best vs. age of the model and the myriad other things that WILL need attention to keep my rig fully operational. This is a situation where ignorance really is bliss. I wheeled the same trails for 15 years on some old, stiff ass leaf springs that were in my last rig and never thought anything of it. Needless to say, moving into a fully locked 80 has been like wheeling in a Caddy so far.
thank you thank you on the ride hieght. if they sale kits only they know they will loose moeny sale bulk an you shal recieve. im eyeing emu next month i might be in market jus dropped 2000 on axles whats another 38 3900 its just moeny for slinkys!!! il pass tooDoes anyone have a hub to fender mesurement of the 50mm and 75mm with a heavy armored up/winch/dual batt 80?
Metric is better, it's all in 10s rather than 12s.
I bought a steel yard stick that's has both on it.
Amerca should of converted over years ago.
They did. At least the government and the military, just not the rest of you schmucks![]()
