- Thread starter
- #381
Woody is running the 50mm HD kit.I believe he has the 75mm intermediate kit.
I have found with my truck that it performs much more balanced and predictable with the Slinkys. I'm not able to pinpoint exactly the reasons other that the design of the coils. Having the extra length in the coils and the longer shocks (compared to the OME J's and L shocks) is the main reason. The OME L shocks would limit travel at full droop and the springs would unload and cause the truck to pitch at unexpected times. Also the OME suspension would rebound harshly when traveling faster through whoops and bumpy tracks. It would compress and then spring back sharply and toss the body of the truck side to side. It wasn't anything I would call dangerous exactly but noticeable and unsettling. I forced me to be more cautious when traveling faster. That was primarily an issue with the shocks.
With the Slinkys the coil and shock length are better matched to range of motion that the factory control arms are capable of with or without swaybars attached. The shocks are tuned to control compression and rebound so much better. There is no more unpredictable behavior or weird pitching of the truck through bumps.
I have never had either swaybar detached (yet) but the front end seems to have better movement than with the OME so front to rear movement is more balanced. Cruise Moab will probably be the first real test for me with the front swaybar detached using LCP's brackets. I'm very curious to see and feel the difference that comes with that.
My point is that I feel much more confident in how I can drive my cruiser with the Slinkys. The balance combined with excellent shock tuning and no strange unpredictable behavior allows me to be more relaxed when driving and I'm going faster. This is good on those longer offroad trips because I can cover more ground and get to camp locations earlier instead of after dark, and be less tired when I get there.
I believe your rig is a perfect example of what a 80 series can do without a 3link. I believe you would be better at showing us what a balanced rig looks like.
I wish we could get a few people here that had some firsthand experience with Slinkys compared to other popular suspensions like OME. Hmmm that would be helpful.This couldn't have anything to do with lowering your truck and its center of gravity by several inches, could it? Going from J springs to J/heavy made mine feel a lot more stable, predictable, etc. too.
From what I've seen of the rigs running the Slinky setup, they aren't utilizing anywhere near the full length of the shocks anyway, so I'm not sure it's from any kind of extra down travel. A case could be made for the shock valving helping out, but I'm not so sure about that either because we would be talking about a lot of extra valving, probably to the point that the oil wouldn't flow through the shock fast enough to stay cool and not fatigue.
My money is on you lowering your rig when you switched, but touting a seat-of-the-pants feeling is not going to offer any kind of conclusive evidence either way, so it's rather pointless to attribute it to something as specific as coil design. Way too many factors to know that for certain.
That is to bad the Superflex arms have such a bad reputation here in the USA. Personally, I have only seen a few other rigs drop out a tire as much as yours. I would say it has to do with freedom of movement the arms give plus length of shocks your rig has. I have been very curious of the Superflex arms & just might go that direction in the future.There's pictures of it out there on mud which can be found via search. I don't think the exotic suspension crowd would like my pile of crap polluting their thread with poser shots.
Besides, I was told by Darren himself that my setup, specifically my choice of radius arms, does not work so surely my rig can't be a good example.
I can understand that. It's not priced to be sold at Walmart.If OME, Slinky, Icon, Dobinson, TuffDog & Tour Flex kits were all 3" & the same price I'm sure our conversations would be much different. Is the resistance to the Slinky kits the price or performance? I believe it's the price.
@richardillard1 you have some firsthand experience with the Slinkys right?? Oh wait, you don't.but you can. Instead of making poor assumptions based on what you read and think, go run a trail or two with someone that has Slinkys. Or better yet, get some for yourself and then come back and give the feedback. I know many would appreciate hearing from more people with actual experience. You're always welcome to come ride with me and see what you think.
From my actual experience along with what I hear from everyone else that actually has the Slinkys, the feedback has been virtually identical and mutually confirming. That consistency says something dontcha think?
The bad behavior I talked about with my OME's has very little to do with center of gravity. The Slinkys are nearly the exact same height as the OME Js. Yes I also had coil spacers but I didn't always. The strange behavior of the springs unloading happened with and without the spacers.
You said you changed from Js to J/heavy. The spring rate is the same between the J and the heavy, the only difference being and additional ~1" of free height with the J spring. You also said it "felt" more stable, but criticized me for a "seat of the pants" review. Pot, meet kettle.
Honestly you should try to at least go for a ride in a truck with Slinkys. Your skepticism about the shocks or coils will go away pretty quickly. I know it has for the people who have ridden with me.
I didn't think my OMEs were bad when I had them. I didn't really have complaints and the weird behavior was something I was used to and figured was just part of how a lifted truck performed.
Once you try something with a better design and performance that's when you realize how significant the shortcomings were with what you were used to.
I'm just giving you a hard time, so don't take it personally. I enjoy the discussion.
The Slinky/Icon Stage 1 2.0 IFP shocks. But hopefully have some of the Stage 4's on the way soon.@Box Rocket what shocks are you running with your Slinky setup ?
A Jeep Renegade might get you down the trail too but it won't be the same experience.
Not everyone will *need* or justify the cost of a high end suspension, in the same way not everyone can justify a BMW M3 for commuting to work. So if someone chooses something less expensive and it satisfies their needs, that's cool. But for someone looking for the best possible performance from a bolt on suspension, then there is going to be a higher cost associated with it.
Just so it's out there and in the "official" Slinky thread. It seems like most people are running the 75mm kit. Due to the height of my wife... and my garage out here in New England, I am really starting to get more interested in the 50mm option. I read @GW Nugget 's build and he gave some really great, detailed pictures and impressions of his 75mm kit. Does anyone have a 50mm kit that would be willing to share some impressions of the springs/shock with pictures of what the travel looks like? Also, can anyone confirm if the 50mm kit uses the same or different shocks as the 75mm kit? I'd just like to have as much information documented as possible.
like meI wish we could get a few people here that had some firsthand experience with Slinkys compared to other popular suspensions like OME. Hmmm that would be helpful.
Are the slinky's a 2.5 shock? Icon's website says their shocks for the 80 are 2.0's. I may have finally found the difference between the two!
And I agree, for consumers, it's the price that's turning folks away. When compared with 4WU 3 link kit, you start wondering what you're getting for your investment. If money was no issue, well a lot of things could be done and said. But like everyone else, I'm on a budget with a goal in mind. I love the slinky reviews, but cost is definitely a deterrent!
Are you suggesting you can 3 link the front of an 80 for what it costs to do the stage 1 kit from Redline ?
