'Murica!
hey that was my first offroad car
The larger MC does require a little bit more muscle input but will render greater braking power.@baldilocks, how quick does your pedal release back when you let off? The one thing I noticed after getting it back together is it is slow to come back up. Haven't had it out enough to see if its causing brake drag or it releases the pads immediately yet. The 1 1/8" bore they sent feels a little stiff but I'm pretty sure I can lock these 37's up pretty effortlessly now...
I set the PV about mid way for now. I may get a set of pressure gauges at some point to dial it in like it should be but with the 6 piston fronts I think I can run it fairly wide open on the rear. The front end is dropping harder than I have ever seen on a couple hard stops making me thing the LSPV was causing heavy rear braking. No proof, just an assumption.The larger MC does require a little bit more muscle input but will render greater braking power.
I didn’t notice the pedal return time increasing enough to concern me. Where is you proportioning valve set? Go in gravel for feting so you can see how long your skid marks are. I set mine so the Fronts lock first making longer skid marks.
Did you get your parts from Matt Sweeting or from Vanco?
Pressure gauges sounds high tech. I used my infrared thermometer and a gravel road. LOL Gen V 4runner fronts are on my list.I set the PV about mid way for now. I may get a set of pressure gauges at some point to dial it in like it should be but with the 6 piston fronts I think I can run it fairly wide open on the rear. The front end is dropping harder than I have ever seen on a couple hard stops making me thing the LSPV was causing heavy rear braking. No proof, just an assumption.
I ended up going Vanco. The owners wife answered right away and is a talker so got really good info and quick delivery. They called this a Toyota "KIT" but I think it's really a tweaked Jeep kit. Outside the mounting bolts(short), flipped mounting plate(180degrees) and I think a short clevis(pulled the pedal down) everything went well.
LOL, I'll likely do the gravel test and never see more but plan on some towing and carry a 250lb bike and 140lb tire on the rear so plan on entertaining it. I think you'll like the Gen 5 calipers, I did a 40MPH - 0 test vs my old setup(35's and no armor anywhere) and gained 10' stopping distance. This was after going very heavy 37's and adding a ton of weight to the 80. I'll test this setup also once I get it dialed in.Pressure gauges sounds high tech. I used my infrared thermometer and a gravel road. LOL Gen V 4runner fronts are on my list.
You know, it's actually growing on me and most the braking is only slight pressure on the pedal. I would take it over pushing the pedal to the floor and not stopping any day tho!@on the rocks I run the same size brakes as you with hydroboost and 1-1/18 as well, I completely agree a 1-1/16” would be perfect
My frustration with failed attempts at making my stock set up work without practically bottoming out the pedal before feeling substantial braking power is what motivated the hydro booster and 1.125” MC install for me. Wheeling rocks with one toe on the brake pedal that strokes an inch and a half at most is far better than needing to pump, pump, and hope as I drop off a boulder or ledge. As for road driving, I never intended to drive a landcruiser like I stole it anyway.You know, it's actually growing on me and most the braking is only slight pressure on the pedal. I would take it over pushing the pedal to the floor and not stopping any day tho!
First, we need to be sure your hoses are properly routed. There should be a high pressure hose from the pump directly to the inlet port of the hydro booster and a high pressure hose from the outlet port of the hydro booster to the inlet port of the steering gear box. Then you can run low pressure hose from the outlet port of the the steering gear box and the return port of the booster to a cooler then back to the reservoir or directly to the res if you are not including a fluid cooler in the system. Both “return hoses can be tee’d together as it seems you’ve already done. My system uses a large PSC reservoir that has two return ports so my return hoses both have their own dedicated hose port with no tee necessary.i need some help pls
i fitting a 2017 f250 sd hydro unit with MC to my 80. i made over lines from pump to run directly to hydro unit and then output of hydro unit goes to steering box and low pressure of hydro and steering box both T up and return to reservoir.
initially i started engine and kept pouring fluid in and kept turning steering wheel. it was HARd and brake pedal rock hard. pedal kept pulsing when i turn wheel. figured i had line mixed up on hyro unit and swapped them. steering is super soft now. however brakes are ROCK hard. i equate it to the old vacuum system with engine off and trying to stop the vehicle.
what do i do? the power steering reservoir squirts fluid out every time i mash brakes. do i have air? is it a bad hyro unit? i have no air in brake lines and did not install a proportion valve. is the rod where the pedal hooks up too long? too short? i cut and welded my oem end onto the ford rod.
I’m not a hydro booster guru. I’ve done two hydro booster set ups in my life on two different vehicles. Both boosters I used were new Bosch units so a bit different than yours.does the bore matter if i am using a complete unit from the FORD? mc and hydro came as one unit from breaker yard.
I did notice that the high pressure output line that goes to the input on the steering box is way larger than the ford factory power steering lines. see pic below for line coming from output of ford hydro unit to the input of the steerign box. its bigger than factory lines so i suspect i am gettign too much flow an dnot enought pressure buildup in de hydro unit. do u have pics of your setup and lines?
Call Vanco, also in SoCal. They are very knowledgeable and good to work with.Just ordered from Matt.......90 days to ship.![]()
