so basically any 1in bore MC that can bolt on is what i need to get?
The FJZ80 has a 1” bore as well. I’ve got my kit from power train integrations. I’m plan on sticking with my FJ MC or getting T100 MC which is 1 1/16What master cylinder are you using? The Superduty hydroboost is same internal displacement as every other hydroboost.
The 80 series steering pressure is more than enough for hydroboost. It's the same as the 7.3 Superduty at 1200 psi.
The master cylinder is a huge factor. I recommend using the stock 100 series 1" bore master. I think it works great.
Are you saying there exists a kit to mount the 4 bolt flange of the T100 MC to the 2 stud mounting surface of the hydro booster?Yeah, that is definitely your problem. The superduty master is HUGE. I'm surprised it works at all.
This kit bolts any 99-2010 Superduty hydroboost into an 80 series or any other toyota with a 4 bolt master.
The 2017 hydroboost you used has some minor differences so it's not compatible with this kit.
I have a Bosch HB. Are the Syed distances the same as the Ford?![]()
1990-1997 80 Series Land Cruiser Hydroboost kit
This kit installs the 2005+ Superduty Hydroboost into any LHD 80 series Land Cruisers. The hydroboost is rotated for maximum clearance.powertrain-integration.com
The bolt spacing and master pushrod lengths are different for every hydroboost variation. Very unlikely my kit would work for your hydroboost.I have a Bosch HB. Are the Syed distances the same as the Ford?
