Hi, I've taken a look at everything. We can salvage and recondition the crankshaft. The bearing bores in the engine block are roughly cleaned and usable. We need to lap and polish the crankshaft, bore and hone the engine block to the first oversize (0.25mm), resurface the engine block, clean the bearing bores, re-tap and wash the threads, and fit the crankshaft and connecting rod bearings. We'll also need to install the camshaft bearings, fit the camshaft, modify the pistons, and angle the connecting rods. Finally, we'll assemble the engine block with the bearings, crankshaft, connecting rods, pistons, camshaft, and oil seal. You'll need to provide pistons in an oversize of 0.25mm with piston rings and piston pins, as well as connecting rod and main bearings in standard size. Please also bring the camshaft bearings in standard size and the camshaft itself. We'll also need the flywheel oil seal. All together, including machining and assembly, the cost will be around €1700. We can talk on the phone next week to see if everything works for you. Have a nice weekend! Best, Philipp
