Build 1979 FJ40 Old School Overhaul
By the time we got to the corner glass... we were worn out!! I was exhausted, our arms and shoulders hurt from all the pushing pulling and fiddling with putting the glass inside the weatherstripping.
The corner glass is where you decide if you are a man or not!!
It is tuff!!
I did the same thing with my windows, 550 cord and a ton of windex!
Although some people say it’s for winos under the bridge.
:rofl: yeah!! It ain't worth a $$hitt for cleaning glass, but it is just slick enough to install ws and glass!!
It was a first go 'round for both of us installing window glass. We caught on pretty fast though. Taking a break for lunch 2/3rds through was the trick. Some Mexican food and 2 beers was just what the doctor ordered. Went back rested and a little looser and presto... All in. My excuse was the leftover jet lag from my trip to Israel.
WOW!
2. Install door lock
3. Install door latch, with linkage installed on latch
4. Then door handle
Do it in this order or you'll learn the hard way
You want the door handle and latch linkage to go together like this and then bolt together (at the tip of the Phillip screwdriver)
So.. I'm on my phone and cant edit.. but we are at step 6... I'll edit when I get in the computer
6. Install window regulator. It bolts up in two different locations.. 4 around the crank and 2 close to the latches
2 bolts here.
The window regulator had a piece of foam weatherstripping that was so degraded I couldn't use it and I dont know if you can order it.
Here it is...
So I went to Michael's and got some craft foam and made me some new pieces. I think it cost me $1.50
I also bought some edge trim. It will work fine on the rear door hinges and tire carrier... I'm sure I will find a few more places to put it...
But it is too small to use on the threshold above the rocker...
