nothing much has changed on the winches or the rig. I did just place a order for two 8274 solenoid covers that AWL_TEQ makes, beautiful covers and looking forward to getting them. I'm not certain if it is acceptable to go into a winch build for your rig, on your 40 build thread but I'm gonna go with it. I have some questions/thoughts.
1. Solenoid replacement
After running through about 12 threads on solenoids for winches and those specific to the 8274 I have came up with some questions. Is the Albright solenoid pack truly the best option out there? I know alot of guys are using these however I kind of like the single solenoid replacements that others have used which is the SMP SS581x solenoids. I lIke the thought of using these because of the simplicity of replacement and ease of install. Could anyone tell me the difference between the ss581x and the ss581?
2. Winch line
I definitely want to replace the lines on both. I also know I want to use synthetic line. The 8274 is capable of holding 150 feet of line, should I replace the full 150 feet or go slightly less like 125 feet? Also what synthetic lines are you all using? I looked online but I honestly don't know crap about the synthetic lines.
3. Motors
Warn wants an arm and a leg for a motor. Is there any reliable motors out there that doesn't break the bank?
Anyways, I ordered a bunch of stuff directly from Warn Friday night for both winches like seals, gaskets, bolts, etc. I am going to go into a parts store and see if they can make the wires with the connectors I need for the power and ground as both have crappy old wiring.
