Build 1969 FJ40 named Mavis
I am drilling out the captive nuts and replacing them with M6 rivnuts. Taking off the trans tunnel is a PITA otherwise.
Also, even with the amount of gear wear present and the bearing walking out, the only noticeable thing was extra noise in 1st.
Of course, shifts are much tighter and smoother now. There is 1/2 inch less lash now
Was that already a new tank?
We can weld it if we fill the tank with water and pipe diesel exhaust into it while welding to displace oxygen. I can provide the diesel exhaust...
Solder is safer. My radiator guy uses an old fashioned fireplace poker iron, a pointed block of metal attached to a rod like you would have seen in a blacksmith shop. He heats the iron with oxy acetylene so that there is neither spark or flame near the tank.
Tank is fine. it is leaking from the fuel line at the junction.
I broke down and bought the CCOT barbed conversion.
Should have done that when I replaced the tank.
That is an inferior product Drew. ONE: a proper bulkhead fitting will be two pieced, so that the barb can have a ball end, like the factory fitting.
TWO: the barb should be 5/16; 1/4” is too restrictive.
I sell the two piece bulkhead fitting for $15.
What would stop me from just shortening the fuel line and using the 2 piece fitting I have. I haven't torn into it yet, but it looks like the fuel line is what broke inside the fittings
I don't see anything wrong with the hardware
Marginal. Cut it open and see for yourself.
It looks like it was assembled with a special press.
The bottom hex has a split bearing that goes over the small barbed end on the line, and then the hex is driven over it probably by a press.
Not impossible with a new fuel line, just tricky.
+1 for Mark's part, I just grabbed one of those when it came to redoing mine, easy peasy.
Mainly did it when replacing all the old fabric-covered original stuff with modern fuel-rated hose, and needed to figure out how to retrofit the tank to a barb-type fitting. I kept my old-school glass filter bowl, however, that thing is cool.
