Paint inside or rhino line?
Alabama
I am having my 79 fj40 painted at the moment. The entire truck is being redone inside and out. He is also going to undercoat the truck. What I want to know is if I should tell him to also put some kind of super liner on the inside of the truck, i.e. bed, floor boards, not dash. Or should I just have him do it the way ccot does it and paint the floor boards and bed with the same shiny paint as outside, which i think is much nicer. I thought that maybe super liner is better because then if the ground of the inside of the car gets scratched then it won't rust. I will probably end up painting the inside the same as the outside, but I just want some input.
Paint - looks much better IMHO. I always wonder why ppl line the tub and floor? If they were after water repelling properties - just wax it. Are they transporting cinder blocks in the tub? Maybe they're trying to avoid trail damage - but if that's the case, it would make more sense to line the exterior of the truck (which some have done).
If I were purchasing a 40 and saw the lining - I would equate it to diamond plating - we all love diamond plating right? NOT. We all wonder what the hell is lurking under there and what are they trying to hide. The lined tub/floorboard thing may be just a fad. Who knows 10 years from now we may look back and say - "I found a good deal on an FJ40 in great shape, but the PO covered the original paint with lining - doh ". Then we'll be seeing posts asking how to get the crap off. Of course this is all an opinion on my part - to each their own. Whatever you decide - do it because YOU want it that way . . . even if that means lining it - so be it.
Depends on where you want to go with it. Due to the shysters who use it to cover/coat rust, no one's gonna want to see it when it comes to resale. Personally, if I'm not worried about resale, I'd use it for the sound deadening and insulation properties. Makes a hell of a difference.
In my opinion, I would defintely rhino-line it. People that don't have it wish they did. Its so much more sturdy and defintely sound deadening. You dont have to worry about keeping it shiny, or spilling/dropping anything. Its also another plus to have if you are going to have the top off.
i'd line x and paint it the outside body color only if you could eventually sand blast it off.
I had mine Rino'd. It was all I could do to find a shop willing to paint the outside with all its different angle, etc. They wouldn't have touched it if I demanded they paint the inside too no matter how much I would have been willing to pay, within reason of course. Take pictures of your rust free floor to prove to the potential doubting Thomas' down the road you weren't hiding anything. Same with diamondplate.
Since you are spending the money, do it the way you want.
I would rhino line for sure the inside and under carriage. NO equating in my mind with rhino line and diamond plating. If I were to do it (and I would love to do it), I would rhino line for sure. Love the texture from a visual standpoint, the scratch resistance (as I live near the sandy beach) for the inside, and I never run the top so weather resistance and the protection for the underside. it would not be a turn off to me to see it in a rig and I think other visual hints would tip me off if it were used for the right reasons or to cover something up.
Land Cruiser or Jeep?
Rhino Liner would be good enough for a Jeep. A cruiser deserves better. I suppose if you have a dented up wheeler where you don't want to deal with current or future rust it would be good enough.
I wouldn't have considered any cruiser with liner on any part.
you should look at Camcrusier13's links to his rig photos in his signature as I 'think' (it looks like it) he has his lined inside AND outside body - interesting. lots of photos there. something to look at and consider.
why yes i do. well the lower half of the outside of the body. take a look
If you don't want to worry about rust, I would definately linex the underside of the tub. The inside is more personal preference in my mind, but I wish I had done the underside and inside of the tub and the undersides of the fenders of mine when I had it all stripped down. I have an aluminum tub so rust isn't a concern, but linex does look nice, and it's a lot tougher than paint. Cruisersolutions does this on most of their restorations now, and it looks nice.
i bought my 79 fj40 couple of months ago. PO replaced both quarters, rear lip, cargo floor and cargo sides. only problem he used flat steel instead of a real rear floor panel. it is smooth with no raised ribs. when rubber mat is in, it sweats or forms mostiure on bed. paint was coming up in 6"-8" sheets. i scraped paint off, sanded, treated the rust, then coated with 2 coats of rust bullit paint. now i am going to line X it. don't care what next owner thinks. i do not want to see any rust there EVER again! plus IH8 re-dos.
paint or rhino
here are before and after rust bullit treatment.
If you look at the builds under the 45 section you will see that a few of us are spraying in a tintable liner both inside and under. You will also see that we replaced all the bad metal too.
Just a thought.
Bedliner in and under... front fenders and firewall too. You can save yourself a lot of coin if you DIY with a brush and roller... I haven't used a shutz gun, so I can't say about that method; however we just tried to use Hippo Liner on my buddies boat with a "professional" undercoating gun, holy:censor: did that thing suck! Hippo liner sucks too, no rubber bits in it, i guess the texture come from the roller or sprayer. If you DIY, plan on a weekend for under and another for inside.
FWIW I used Herculiner and I'm quite happy with it.
