Had JIS tool. Had two stripped screws. It's a suck project
But is there a downside?But why? There is no benefit.
The OEM screws work best when pre-coated with factory red coolant prior to installation.....
@ElPolloBlanco I also have some Torx & Torq screws & bits waiting to go to good use. What size did you use? I know that some American Fine threads do match some metric. Or a better question is what is the size & pitch of those oil pump screws?We used Torx on F-18's. They'll strip if the wrong electrician is sent out to remove the panels. Hate those guys. I replaced my screws with Torx when I did my seal. I already had a Torx tip set.
Nope, a #3 Phillips, tapped in with a hammer is the ticket, just as the OP suggests. Very tight, snug fit.
My point was that you could have skipped that step all together if you would have bought jis bits.
