Hi Guys, I am half way through my project, which includes radiator replacement, front crank oil seal, oil pump seal, belts, hoses, pulleys, etc. I do not know if someone else has posted this before, so I just add my two cents. I removed the battery in order to remove the radiator, once the radiator was out, I moved on to the crank bolt using bump start breaker bar methods. I used jump cable to hook up the battery to my truck, bump started few time without success, after 2 days of thinking of weak battery or starter motor, I realized that the jump cable might be the problem. So this morning I put the battery back into the truck, set everything in places and turned the key, the bolt got loose after first try.
Hope this helps.
Hope this helps.
