I've noticed a few write ups about adding vents to the hood for low speed heat dissipation. I remember my FJ62 having a plastic (removable) plate at the top of the firewall just below the factory vents (by the wipers). The 80 doesn't have this plate but there is hollow space right behind the fire wall. If you were to cut out an area similar to the FJ62 opening, I wonder if it would allow much heat to escape out of the factory vents. The passenger side is a little more crowded but I assume something could be done there as well.
Is there too much negative air flow where the hood meets the windshield to make this effective? Thoughts?
I guess a small fan could be added also if need be.
