norsk
- Thread starter
- #541
Took the starter off this morning and tested it. Engagement worked just fine. SO I called the vendor/dealer in Tenn. (Skip White) and got tech support. I learned something.
I already knew I had a 168 tooth flywheel, and that there was a 153 tooth as well. I had installed the starter in the 153 tooth flywheel holes on the starter moving the starter too close to the block and what was happening was the small gear was just ramming the front of the flywheel.
Reinstalled in the outer bolt holes of the starter to allow it to mesh with the larger flywheel. I hooked the battery cable up and tested it by turning the key...........The motor turned and no bad sounds came from the starter.
Cranked for 30 some seconds and started to get back fires out the exhaust. Asked jake to come listen and he twisted the dizzy (advancing it) while I cranked. It began to run on its own but poorly - more advancing and it got better and then idled well on its own. Found some noise sources and turned off the engine. Tightened down the alternator as it was a source for a noise then looked for leaks. Driver's side exhaust donut seems to be leaking, need to loosen, adjust and tighten back up to get rid of that.
(Also need to set Idle timing with the light)
Then got the camera recording and started it again and took the video of it running.
So in conclusion: IT STARTED TODAY without breaking something
video is down below
dougbert
video is down below
dougbert
