What bell housing are you using?
What did you guys use for the manual shutoff pull cable?
Detcord sounds like a fun idea.
Another question I just remembered, should I connect the sense line for the alternator at the battery or can I connect it at the 12v output on the alternator? ASTR's swap had this discussion but it didn't seem to come to a clear conclusion. I think the FJ60 alternator did it at the alternator and the sense line is not on the connector. I would think voltage drop across an approximatly 6ft 10gauge wire won't be very high.
It probably won't make a whole lot of difference but I would connect it at the battery. After all, you want to regulate the voltage as it appears at the battery. The whole point of having a separate sense line is to allow sampling the voltage at the critical point (battery) and adjusting the alternator output accordingly. With the sense line tied to the alternator output, you could be limiting your maximum alternator output because, the higher the output current, the higher will be the voltage drop. At 65 amps (the rating of your alternator) you will experience 0.4 volt drop over 6 ft. using #10 wire. And that is assuming perfect connection (0 resistance).
Secondly, I would suggest using #4 or #6 minimum wire between your alternator output and the battery.
Good to see that you are making some progress and feeling better about the swap.
I think the slave will be fine.
I ran my sense wire at the alt. seems to work just fine.
Any reason you didn't do an electronic shut off?
Clint
mounted the inline electric fuel pump,
