- Thread starter
- #401
Funny guy! Do you keep your 75 keys under the mat too?
Yes, but based upon other posts I have seen, I suspect that you're pretty handy with a firearm - a good deterrentYes ...... I'm a trusting guy.
It's a pain in the arse, but with a wire brush, a strong solvent and a lot of patience, your old cable (which looked just like mine) can look like this.Oil change, well a failed oil change and pto un-seizing. 7pm to 2am. Last oil change they must have cranked on the oil filter bc no one could get it off. So had to fill it back up with fresh oil. Oil wrench we had was too big and hands, leather belts, webbing, taped hands for extra grip, etc couldn't get it.
Pto was pulled out and couldn't open the area to look at the drive so we first check to see if any fluid was in there. There was, but looked like automatic transmission fluid. We filled it up with anti lock spray (or whatever it is called) and some kind of other oil (turbine oil?). Let it sit for 30min or so then took a pipe wrench to the connection thing and took a while but finally broke it free. Let it sit longer. Turned it a bit. Drained it and a lot of rust came out, then added gear oil. Put pto back in. Found a nail. Worked like a champ until tried a faster gear. Snapped the nail under pulling its own weight. Couldn't knock the nail out so had to pull it out again. Finally got it drilled and pounded out. Put a hardened steel Allen wrench. Put it back together spooled it out and repeated, but kept it slow. Put it under a bit of a load by holding the breaks a bit and you could hear the rust still in there and the racket coming from inside the winch.
Going to run it for a week or so under a light load then drain and refill. Try and start clearing out the rust.
Still need to get oil filter off though. Doh!
View attachment 1102011View attachment 1102012View attachment 1102013View attachment 1102014
