I am wondering what the difference is between the stock master and the non abs master? Does anyone know if the abs master have a limiter for the rear circuit in it?
usually there is a valve to compensate for the rear drum brakes I believe, but that's in fj40's......Don't non-ABS 80s have rear drum brakes? I had assumed the different master was related to that.
belmetric.com
I have mine sitting in the garage if you need itLooking for a good used 1995-1997 ABS Pump with minimal corrosion. Let me know if any of you still have your old one.
I have both Advics (Aisin) MCs here, BMT303 and BMT068 with 068 being first gen ABS (93-94) and the 303 being the later model NON ABS. Aisin has superseded most part numbers on the early 1FZs to just two, the 303 for non ABS, and 068 for ABS applications. If you search their online catalog, there are a few others, but they are all in a discontinued status, so just exhausting existing stock.I am wondering what the difference is between the stock master and the non abs master? Does anyone know if the abs master have a limiter for the rear circuit in it?
In this thread, there should be a part number for a T somewhere. I think the T from the rear axle.Ok I give up! Can someone help me find a suitable replacement for the "T" fitting after an ABS/LSPV delete? I bled everything today and tightened it all up but it's still leaking. I unscrewed it fully and cleaned everything out, tightened back down but still leaks.
It's leaking from the front fitting.
I’ve got one I’ve removed, PM me with offer.Also looking for a good working abs pump for a 95-97 Land Cruiser. Shoot me a message if you have one for sale. Thanks!
Thank you... I scoured all 14 pages and few other theads as well, but may have missed it. Back into the depths I go.In this thread, there should be a part number for a T somewhere. I think the T from the rear axle.
Oh sorry, I could have swore I remembered seeing one. I’ll check around.Thank you... I scoured all 14 pages and few other theads as well, but may have missed it. Back into the depths I go.
I'm not real familiar with the types of flared threads out there (10mm, double inverted, bubble etc) so I'm not exactly sure what to look for.
I think I found it! So M10x1.0 T fitting? Inverted flare?There are many M10x1.0 T fitting options direct from Toyota if you need one. Go to Partsouq and search any Toyota SUV or truck, in the brake section. One I chose, for other reasons, because it has mounting as well you can modify and tie to the fender, 90412-A0005 ($16-$20).
Check this thread.I think I found it! So M10x1.0 T fitting? Inverted flare?
forum.ih8mud.com
Awesome! Thank you. Part ordered. Just in case anybody else here needs one.Check this thread.
Source for 3 way brake fitting that fits our M10 x 1.0 inverted flare brake lines?
I need a brake line 3 way fitting (maybe called a T fitting?) that fits our 80 series. I tried to order a 90413-10058 (the 3 way fitting that sits under the master cylinder on ABS 80 series) but apparently, those are no longer available. And to be clear, I don't need the bracket that attaches...forum.ih8mud.com
Bad news... that part is NLA, according to the 10 dealers I spoke with. Searching for another suitable replacement.
