I wonder how Icon does it then? I know that they use new frames, not sure if they fab them themselves or if they buy them. But I can certainly understand not wanting to risk it.A new frame is completely out of the question. Calif states the frame is the vehicle; the chassis on top of the frame means nothing. I called several departments and got the same answer.
In the case of a new frame, the vehicle is considered new construction; you get a brand new vin stamped AND the year is based upon the engine.
I'm sure people have gotten away with gray area frame swaps. I don't trust my luck and I'm not willing to gamble loosing a vehicle over the attempt.
I think by plating that much as you have so far your going to put more force on stock parts of the frame flexing and risking fatigue and cracks. I think your moving away from it being a flexible frame and moving toward a rigid frame at this point. So yes in this scenario I would box the rear of the frame. I would also plate the radiator cross member or just cut it out and install a beefy one. I would buy the ruffstuff kit if shop labor is high and you think it would save the cost of labor. I would think that cutting out the torque tubes and installing square or rectangle tube instead would reduce chassis flex significantly as well. Just a thought. Just my opinion, not sure if its any good. That fab work looks great.As this picture shows, most of the front outside 1/3 of the frame is plated:
This plating takes care of anything I need for the Scout PS conversion I'll be going with along with shock mounts.
It is the back 1/4 that makes me think too much.
He makes things look too easy and too clean.
He did the following for the front of one of my FJ55s:
I post up some of my bad work for 'good ideas, execution is off' or 'bad ideas'![]()
