ARCHIVE Wits' End Turbo Test Mule #3- no cartwheeling allowed
It has a lot of texture, kind of like sandpaper, and gets very dirty and grungy quickly. It doesn't look good but still works the same.
I know this is your show rig but degraded in what way - hard to clean, flaking, ...? I’ve only seen pictures of them as bright white. POR-15 or VHT for aesthetics.
Something really cool finally showed up out of Australia. On the Toyota #1FZ blocks we get to enjoy a timing chain instead of a silly belt. The timing chain has a timing chain guide and adjuster. The adjuster, located just above the thermostat, is hydraulic and uses oil pressure to keep slack off the timing chain. Low oil pressure, wear, etc keeps the adjuster loose and it’s what makes your timing chain noisy. There are lots of noisy timing chains out there.
This bad boy is self-adjusting. It has a firm spring pushing the adjuster forward all the time. But it goes one step further, it has a ratcheting anti-reversing lock built into it. As the timing guides where AND the adjuster adjusts, it will click and prevent the adjuster from going slack. Really smart setup. Although neither of my LX450s needs it currently, I will be trying it out on the turbo truck. Excited to see and hear the difference.
View attachment 2155926View attachment 2155927
Nice, my old Suzuki DRZ-400 had a similar setup. Solid peace of mind.
Now that is cool.
Do you have a part number for this?
it’s a modified piece designed to work with the 1FZ.
So an aftermarket product? Any more info to assist a purchase of one?
We’re the cool kids !
