Yup, I have a squeaker on the driver side and it was a Slee install. I will try the PTFE lube that was posted earlier.
Probably better to get ahead of it by using the lube now. The bushings are exposed to a lot of heat and water, and the supplied grease is pretty thin and washes/pushes out. That you have to essentially take the UCA off to add more grease is a short cut SPC used in manufacturing. A zerk wouldn't have been much added cost. But it did add quite a bit of hassle to the end user.
