Two more considerations:
Grease:
Always use grease that states on the can for "wheel bearings" or high speed.
Snap ring gap:
Very important to have a vary good snap ring (new OEM) with sharp edges, tight around axle and thick enough so gap is less than 0.20mm between it and hub flange
When checking snap ring gap. It's important to pull axle out as hard as you can. If axle bearing and bushing (brass bushing) was greased. The grease will be between brass bushing and front drive shaft in back of knuckle. This grease needs to be settled or squished so that we get a true gap reading. Just pulling on axle by hand will not do the job, if grease was just packed in. Either drive to settle. Then come back and pull axle by hand, by threading a 8x1.25mm bolt in end of axle. Or set up a puller to pull axle out settling grease.
Notice bottle jack is raising LCA so that front drive shaft is lined up, eliminating axle from pulling back.
If grease has been settled by driving. Then just threading a 8x1.25mm bolt in end of axle and pulling, is all that is needed to check gap.
With fresh grease on brass axle bushing, I pull to settle. With clamp on back of caliper (not on dust shield) I crank puller tight. Pulling out axle to settle grease I just packed in back of knuckle on brass bushing. This insure I'm reading true gap.
