Cleaned the underhood with dishwashing soap...
Put transfer case back together, THEN notice the countershaft bearing on the bench.![]()
Hello RWBeringer4x4,Finally got my new quadrajet from Sean Murphy Inductions dialed in. Had to fight a couple vacuum leaks and idle mixture issues but the truck now idles beautifully at 650RPM. The best I could get out of my old Buick Qjet was about 800RPM, which had a ten dance to wander up to 1000 after a few miles.
Now I've got good throttle response, and no real stumbles. Most importantly, it starts without having to crank it for 2 minutes.
Ye olde 283 seems to like about 14 degrees advance timing, which gives me about 38 degrees at throttle.
Now it's just a matter of saving my pennies in order to pull the whole engine, and either replace or reseal it, then drop it back in with new mounts in the proper location.
Chomping
Can you tell me or pm me what throttle cable set up you have and what the length is? Did you have to modify the peddle. I'm having issues with the throttle cable set up I have after putting in a quadrajet.
Thank you,
Rob
Jeff : simply a personal thought your truck would look good & rugged with glossy black bedliner (such as Monstaliner) on the doors, hood & fenders? ~MarcMounted the hood, drivers side fender and drivers side turn signal
View attachment 1153049 View attachment 1153050
It's a 1970 f155.Juan what year is your rig, that cleaned up nice!
