What have you done to your Land Cruiser this week?
I’ve been chasing a speed induced wobble for a while. It started in the back so naturally I figured it was the pinion angle from that nice new Tom Woods driveshaft (I never start with the easy things). Messed with that for a bit; wedges and angle calculators. It has had the wobble between 38 and 43 mph ever since I built it so naturally I assumed I f’d something up. A couple weeks ago I rotated the tires and that wobble moved to the front. Today I took it back to the independent tire shop in town and had them rebalance all four tires. They were all way off and now it drives like a dream. Just another example of me way overthinking an issue. Such a simple solution, such a hard head.
Yes, that balancing act on 3 floor jacks was pretty sketchy. 😂
They really just jacked up your ride with three jacks, in the street? And couldn't be bothered to use stands?
No wonder they couldn't get the balance right.
I'm just like you. One little tick in the engine bay and I'm ready for a full rebuild. Also...that floor jack situation stresses me out!
All so I thought about deflating the tires but it was getting late and was out in the sun for a few hrs prior and didn’t feel like messing with it at the time.
My wife and kids are catching a movie on Tuesday so I might attempt it then. Haven’t decided if I’m going to start it in the garage while they are gone or just deflate the tires and start it outside.
Did you get to start it this week?
did you get an opportunity to start it this week? Just curious. 👍
I have not but hopefully I can tomorrow. Thanks for asking. I also ordered 1 1/2 shackles and should arrive on Monday.
So I deflected the rear tires just enough to get the cruiser out. Ended up having to charge the battery for a few.
After charging the battery I pump the gas pedal several times and possibly more than I should have. The motor was turning but wouldn’t start. However in between doing so my daughter came out and jumped in the drivers seat asking about how the knobs worked as far if you pull them out or something similar. Upon her doing that I realized I didn’t pull the choke. It’s been so long since I was in a cruiser I completely forgot about it.
However I never got it to start and I believe I flooded the hell out of it. Once I check to make sure it’s running smoothly I’m putting a sniper on it.
I’m sure you don’t need any Sniper motivational speeches and it’s not that a great carburetor does not perform BUT one of the greatest pleasures I get from my Sniper is the amazing instant starts. In my decades of owning land cruisers or older cars that are not regular drivers, if I don’t start it within a week or 10 days ..that start process takes a quite a few cranks.
With the Sniper..I turn the key, pressurize the fuel and it always just starts instantly. Good luck with that decision. But you’ve probably already decided
Yeah I already bought most of the accessories for the conversion. I haven’t bought the unit itself yet. I’m waiting to make sure my engine preforms like it should first.
I recognize that shop - Good people. Imagine seeing 3 floor jacks under a one-ton…just say’n.
I would be interested in your carb core.😊
Coming along nicely!!!
Lastly, I did something that I had been curious to try for a while . I cut two pieces of 1/8" thick shim stock, drilled a hole in each, and slipped them through the access hole to go between the two main channels and the inner door skin. This had the intended effect of tipping the upper door frame in slightly, closing the gap with the hardtop nicely.😊
That's a really cool idea! I need to try that when we put the doors back together.
Drove it 450 miles today up to the Navarro River so they must have done something right. Funny thing was as I came out of the office and saw it sitting like that it started to roll backwards. Went about an inch and a pebble caught one of the steel wheels on the floorjack. That’s when I walked up front and took a picture. I figured the insurance company would appreciate it.
What thickness are those spacers? I have 1/2" spacers on mine and the nuts are on there half depth. Yours seems to fully engage the studs.
Budget doesn’t allow for new wheels which are really thick. These spacers are 1”.
Have you tried the open “tuner” lug nuts which pass through the wheel to pick up more threads on the stud?
Edit to include link-
Open Shouldered Lug Nuts
Replaced dry rotted rear window rubber via city racer.
Very satisfying 1:banana:job.
The problem I'm having is the bolts that hold the spacers to the hats (discs brakes). Because the spacers are 1/2" thick, I have about 1/2 a nuts worth of engagement. If the nuts were any thicker, the nuts would interfere with the rims and not allow it to sit flush against the spacer. They haven't backed out or even loosened up at all, but it's always on my mind. I'd have to loose a wheel on the freeway. I'll try to get a pic this weekend.
