cool as H
The openings on the inside of the door are mostly for access to the internal door handle mechanism and the latch. However, I do sometimes use them as storage, they are a pretty good place to store small things like some suntanning oil or dry bikinis to change into after a swim.@Aloha Jen are the port openings on the inside open to the floor or are there “shelves” in those storage pocket openings?
I applaud you man, living the life. You can never have too many surfboards or land cruisers.
Well, surfboards and Land Cruisers happen to be the two most abundant things that seem to be always multiplying at my house!Surfboards and Cruisers would be a good cruiser meet up theme.
The tailgate we put in was a home made one we fabbed up. Since this Dune beige 40 was always going to go topless here in Hawaii, we made a bolt on tailgate (bolted to the factory hinge areas and to the bottom door latch area). It’s very strong and was made to bolt a fuel can carrier as well as the stock license plate holder.@Aloha Jen I cant remember on your build, what tailgate did you use? Thanks!
Talk about "Super Handy"The tailgate we put in was a home made one we fabbed up. Since this Dune beige 40 was always going to go topless here in Hawaii, we made a bolt on tailgate (bolted to the factory hinge areas and to the bottom door latch area). It’s very strong and was made to bolt a fuel can carrier as well as the stock license plate holder.
Then painted it to match the body color and then rhino lined the inside to match the interior bed. Very happy with how it turned out, and, it was basically free because we used scrap pieces of metal and some extra stock door hinges to make it.
I counted 4 beautiful LandCruisers ...and possibly 20 boards!The openings on the inside of the door are mostly for access to the internal door handle mechanism and the latch. However, I do sometimes use them as storage, they are a pretty good place to store small things like some suntanning oil or dry bikinis to change into after a swim.
Sadly, I only own/use one of those surfboards (a 9ft longboard)… the rest are families, visiting friends or just happen to find their way to my garage (much like the Land Cruisers!).
SPECTACULARThe tailgate we put in was a home made one we fabbed up. Since this Dune beige 40 was always going to go topless here in Hawaii, we made a bolt on tailgate (bolted to the factory hinge areas and to the bottom door latch area). It’s very strong and was made to bolt a fuel can carrier as well as the stock license plate holder.
035 works just fine.I was told to look for small wire ,025 and use gas for best results.
If you are seasoned, sure.035 works just fine.
You don't want to weld it....you want to tack it....here, there, somewhere else but not here again for a bit.If you are seasoned, sure.
Smaller wire really helps to learn to weld thin metal.
OkYou don't want to weld it....you want to tack it....here, there, somewhere else but not here again for a bit.
It was a nightmare today. I'd do one good weld and then blow 3 holes in it.For Body sheet metal a 110v welder, .023 solid wire and c25 gas.
I would hate to use anything else. ( Thicker solid wire or flux core)
My last project I tacked them with the MIG with that setup and TIG welded them solid for fun.
