Drove it to a small car show on base.
The idea of a ‘third brake light’ (or center mounted stop light) is that it’s just a brake light, to get your attention. Granted, I get what you’re saying about functionality though.I like the idea and the execution here on the lights.
Does it blink with a blinker?
I definitely like traditional look, however visibility is key.
This is essentially a lack of visibility….
My friend Cathy is a 76 yr old experienced rider….and this was the classic left turn in front of her approach to the intersection.
Both wrists broken, broken neck fractured ribs and some internal bleeding. She gets out of the hospital and into rehab tomorrow after 8 days
Visibilty !!
I had my MSD box mounted there and it worked out well... it was well above the waterline as well.So, is anyone else running a Holley Sniper EFI and a HyperSpark Ignition? I am looking for a place to mount the CDI ignition box and I just don’t see any room … looking for a few suggestions…. My MUD friend @jhsmith suggested inside the glove box…I will use this as a last resort but would prefer the engine compartment. he has also suggested adding a standoff where the 90 degree speedometer thing is mounted and going directly over it but about 4” off the firewall or relocating the speedo thing
I understand the “third brake light”The idea of a ‘third brake light’ (or center mounted stop light) is that it’s just a brake light, to get your attention. Granted, I get what you’re saying about functionality though.
FWIW - my 3rd light is connected through a trailer harness that I installed when I built my new rear harness. However, that light is only connected into the running lights circuit as well as the brake light circuit.I understand the “third brake light”
Mostly wondering how people are hooking it up
So that it doesn’t blink with the rear turn signal.
Although I am on an older cruiser with simple tail lights not the newer style where brake and turn is separate from OEM.
I suppose I can just run a new wire from the brake switch output signal.
I used the space on the right of the glove box (where stock radio speaker went), under the dash to mount my relay box for my fj80 front elocker. I made it out of fallen aluminum road sign and mounted it with riv-nuts. Details and pics if you want them.So, is anyone else running a Holley Sniper EFI and a HyperSpark Ignition? I am looking for a place to mount the CDI ignition box and I just don’t see any room … looking for a few suggestions…. My MUD friend @jhsmith suggested inside the glove box…I will use this as a last resort but would prefer the engine compartment. he has also suggested adding a standoff where the 90 degree speedometer thing is mounted and going directly over it but about 4” off the firewall or relocating the speedo thing
That is a slick mod!It’s a great little upgrade, especially with oversized tires on the carrier that can partially obscure your lower brake light.
