I just and replaced the bottom of mine.With the amount of rust that would be the best plan.
Disconnect the negative, set a test meter to DCv milliamps. Put the probes between the neg battery post and the disconnect clamp on the truck harness. You should not see any voltage being drawn with the key off and truck not running. If you do. Something is shorting out and draining your battery.@mef0629 I'd disconnect the negative terminal on the battery. Not knowing where that juice is going wouldn't let me sleep at night. A long time ago, I'd use a quick disconnect knife-switch on the negative terminal...
I had a cowl seam water-short in the my stereo, and the always-on source of power energized the ignition-on side of the radio, walked by the truck, heard music.
Along with your write up. Would you mind laying a straight edge on the lower outer part of the door and shoot some pics or post some measurements? Curious how much oil can effect there is on the door or should it be dead flat?Door repair compete. Ran out of reducer so I can’t paint until this weekend.
I will do a write up soon. I used topnault repair panels, the reason for not using CCOT this time is that the rust went up too high on the inner panels of both front doors. Topnault panels go half way up the door!
In final 2k sandable primer ready to be sanded and sprayed.
I drenched the inside bottom of the doors with SPI epoxy primer, when I’m done I will spray galvanizing spray from the welding shop and clear over that.
Yesterday I welded the last panel, body filled both doors, epoxy primed all in 12 hours on a dirt floor. I’m tired.
Now I need to find all of the replacement components for the doors.
View attachment 3696687View attachment 3696688View attachment 3696689View attachment 3696690
My guess. The inside of the exterior skin of the door likely experienced significant surface rust. What that did is it relieves the internal stress of the steel on the inside. Because steel always has internal stresses from manufacturing, rust will influence it to the point that it elongates, yet the outside panel's exterior is still in tension, so it overall puckers.Along with your write up. Would you mind laying a straight edge on the lower outer part of the door and shoot some pics or post some measurements? Curious how much oil can effect there is on the door or should it be dead flat?
Early in my restoration I outsourced the door body work and the dude royally F’ed it up. I’m considering cutting his patches off and starting over but I’m struggling to find a reference of what it should be.
This is how he gave it back to me. Look at that ridge on the patch vs the door.
I spent an hour or so heat shrinking and hammer dolly working to get it leveled a bit. Then I got angry and walked away. The problem is that it’s oil canned somewhat because his patch was flat and the door material was oil canned onto that flat patch so I tried to work the same curvature as the door material but I don’t know if that curvature should be there?
View attachment 3697827Still needs a ton of work. Should I stop and re/patch or keep working it to a smooth oil canned shape?
Thanks a ton.
Public Service Announcement: do your own work. Don’t do what I did thinking I could outsource and get a good result.
‘That’s a nice Jeep you have!’View attachment 3698302Grocery getter. Took my wife to get a few items. Sitting here watching people check the ole Landcruiser out. Good times!
Here’s a stupid duck‘That’s a nice Jeep you have!’
I finally learned today what the ducks are for! They melt them down to make new plastic tie rod ends!!Here’s a stupid duck
Can you show me the straight edge down to the bottom of the door please so run it from under the ridge to the very bottom.Along with your write up. Would you mind laying a straight edge on the lower outer part of the door and shoot some pics or post some measurements? Curious how much oil can effect there is on the door or should it be dead flat?
Thanks a ton.
Yes, if you are building a concourse show winner. Also you would need to know how to do it and own the proper tools or you will warp the whole thing.I thought if a panel is actually "oil canning" the metal needs to be shrunk to stabilize it?
The light visibility on the back of a FJ40 is horrible. The upgrade by Jen is a great idea and very clean. Well DoneThe idea @Aloha Jen used for her third taillight is infinitely easier. I did have an extra rear hubcap and I had trouble locating the lamps that Jen used so I felt it time to be creative. All I had located was 4” tail lamp. I looked all over the internet, Amazon, and retailers locally including Harbor Freight. Since messaging Jen … she pointed me in the right direction for the same lamp she used and it will be here tomorrow. I searched 4” and hers is a 5”.
The lamp I did have is about 4.25” so while it fit in the front hubcap cutout, I felt it could be more secure especially that Jen had it screwed in place. This grommeted one uses a lip and groove to secure itself in hole and It stays in place. Since the hubcap has a pointed shape, it acts as a centering hole for the pilot on the hole saw and kept it centered. The provided template matched the hole saw perfectly.
Oil on the cutter is a friend as is a tight grip on the hubcap, the cut is quick with the thin metal in the hubcap. I am using both of these on 2 different vehicles. One thing about visibility….there can never be enough!
Rubber on glass first, then install into door opening. Rope trick works great, a cotter pin puller tool is very useful as well.Having another question of re-installing the window seal on the ambulance door. Do I keep the rubber on the window and start at the bottom using the string method or set the rubber on the door frame and try to wedge the glass into the groove?
Anyone have a suggestion having done it before?
Mine 1st door that I have patched did the same thing. I tried portapowering it back up and heating an cooling. Finally after I got it to within a 1/16", I filled it with filler to get it flat.Along with your write up. Would you mind laying a straight edge on the lower outer part of the door and shoot some pics or post some measurements? Curious how much oil can effect there is on the door or should it be dead flat?
Thanks a ton.
