What have you done to your Land Cruiser this week?
I definitely understand what you're saying, but wouldn't a smaller diameter washer do the same thing without having a 'specialty' washer that is cupped?
I think in compression the material would want to "spill out" over the edge of a smaller diameter washer and it would create a wear point at that diameter. I would imagine a flare eases that transition
That is true. They should cup away from the rubber portion and ride on the center metal spacer. Note in pic through fender washers get installed opposite of being mounted on a bracket.
Hmm... not sure I follow the logic here. Nearly 30 years in the same cruiser, changed the shocks 4 times and always put the cupped side inward. Never noticed any wear or adverse effects so I'm leaving them that way.
Started replacing the rusted section of my trans hump.
- Made a templete
- Cut a piece from the donor hump
- Cut out the rusted piece
- Started shaping the new piece
I will weld in the new piece and and finish the job tomorrow :)
You’re lucky to be alive! ;)
Taught 30+ years ago the cupped faces out on horizontal shock bushing to allow a bit of twisting movement in the bushing and relieve the cylinder excess force on it … the twisting of the bushing is always there… it needs to
You don’t want to clamp down on the castle nut and squeeze the piss out of the bushing … it will not be able to then move… it’s a castle nut so it can be tight enough to do its job… but could loosen and therefore a cotter pin prevents it from that
The cup however faces inward on vertical shock bushings as they are under compression… the cup holds the compressed bushing
Imho It’s all very marginal on a DD … on a suspension that is under constant hard stress could break a shock mount or shock it self
My 2c :)
I love these tires! The fj40 came with the tires when I bought it and I bought a spare for it. I have always been a bfg all terrain fan but I would buy these again. They are more mud terrain than all terrain. but not loud like mud terrains can be. I think they are near perfect on these fj40s. Looks like if you are in a snowy area the tires have places for studs. I dont have much snow where I live though. I think they would also look really good on a 80s toyota truck.
I do think they are more like 10 inches wide vrs 9.50s. Ill measure after work to confirm.
The side walls are not my favorite either but its not the worst.
I love it but in a classic way ..... I woke up and it was raining this morning. good thing I put the cover on it last night.
I have noticed these tires are getting a lot of love on mud lately. Sounds like they get good reviews for highway use. My BFG’s are about done, and I see they offer a 35”. Mine is mostly highway driving, but I like to go to southern Utah for wheeling. Has anyone used them in the rocks?
the washers were installed correctly. The upped side goes away from the bushing on eyelet type shocks. On a post style shock like a 60 or 80 front top
mount, the washers go cup side toward bushing. The washers are a different shape on the two styles
Thanks Dave…to me anyway, a picture is worth a thousand words.
Have you tested it at 60 mph? Yuma to PB cabin?
Apparently I tested it at 75 mph. The Speedo doesn't work, my coworker was following me and first thing he said was "man that thing runs pretty good huh?"
I'll make it up that way next trip out Dave. Would love to put a proper grill guard on it.
Would the person who made that be interested in making another?
Yes, I'm going to take the 40 back to him next time I'm in town and have a few sets made.
Replaced the power steering pump, last one had a small shaft seal leak that slung a nice black sludge as the oil burned on the belt inside the hood and fender. Also added tweeter speakers, snuck the wire under the knee pads and held in place with two sided tape. The most amazing part is both repairs came out well the first time, weird…
How doyou likethe tweeters while driving? Been considering that addition for a while now. Need a little more sound at the ears!
I made a thing. It works for now. Paint will make it look slightly more acceptable.
That's a good idea. You could probably get by without the bottom tube section and just terminate each side at the saddle, saving the clearance.
I would put in some short tubes/bushings in the mount holes if you haven't already.
