Still wire brushing oily mud off of the transfer case when I have a free minute or two. I changed my mind about hooking up the heaters, and installed a by-pass until I look them over better. Chased coolant leaks for an afternoon, including a surprising one in the middle of the hard line over the 2F push rod cover-had a spare from the original 2F, and the balancing act of torquing the two screws which sandwich the thermostat housing. Hooked up appropriate Auxiliary Accelerator Pump, Power Valve, and Choke Breaker vacuum lines; vac capped the vacuum retard and fuel vapor burn-off. Installed a new OEM fuel filter, fuel hard lines, gas tank filter to vent to atmosphere. Installed a PCV valve and line to manifold. Hooked up choke cable. Installed battery negative cable to alternator bracket. Cleaned oily soil from the region around the oil pan drain plug. Installed dino, gas-engine 10W40 oil in the crankcase. Bought gas for the tank, but I just might drain it and install the new 'stock' tank that I purchased back when I only had time to sweep and shovel snow. Next week should be more about getting spark and a temporary exhaust route behind the header.
