Turns out the trail tailor recovery points won't work for my application. Not the fault of @reevesci, more the fault of ARB.
Its frustrating they decided to box in the stock recovery bolts and not include any options for front recovery. Makes the situation difficult.
The only way to get it to work would be to flip the bracket so it faces towards the tires, opposite of what's in the photo, but because the way the ARB is designed, the bracket can't mount that way because it will hit the wall. Another issue with the way it is, is the d-rings is pressed up against what I think is the tranny cooler intake or exhaust line. So any movement and it will break the metal fluid line.
Only solution I can think of is to cut at the wall blocking the bracket then weld the bracket to the bumper to create a new wall.
The bracket also wasn't quite long enough to reach past the wall of the bumper. So I did have to cut it a bit to get the pin through the hole, to where I discovered the issue with the fluid line.
