So much for Toyota quality. Was able to file most of it out prior to install.
Sent from my SM-G900V
got some new rims and shoes
275/70R18 BFG AT KO2's
Water pump inlet.What are we looking at there? Looks like an intake manifold runner?
Is B1S2 the code it threw?Replaced the drivers side rear (B1S2) Oxygen sensor with Denso 234-4260 @ 126k kms / 79k miles. A little early for an O2 sensor to go out, but I'll attribute it to the northern climate (if for no reason other than to make myself feel better).
The truck threw P0137, which aligns with B1S2. I used Techstream to check the codes and to clear them. Annoyingly, with that code active some portion of traction control (I can't recall which) was disabled. Not a desirable condition in a northern Albertan winter.Is B1S2 the code it threw?
Every have any cooling issues before de-burring, what year is that from?Water pump inlet.
Seems strange traction control be effected, could it be secondary issue unrelated to O2.The truck threw P0137, which aligns with B1S2. I used Techstream to check the codes and to clear them. Annoyingly, with that code active some portion of traction control (I can't recall which) was disabled. Not a desirable condition in a northern Albertan winter.
I haven't driven it yet to verify that the problem is solved, but the code didn't immediately return after clearing.
I had my windshield replaced by Abra (who the local Toyota dealership uses for glass) and it's every bit as good as the OEM, imo. I even had the choice of tint color based on my OEM tint. Very happy with the results.Monday I am getting the windshield replaced which I am gutted about as I am not going to be using an OEM as it would have been $1300. Guessing the aftermarket one does not have UV rejection.
Water pump inlet.
Not cool... I would want to send it back, but you probably needed the part right then...
Compounded and waxed last weekend as well as pulled all faided moulding off to replace with new.
Pulled all carpet out, took out console and removed door panels this weekend - all new carpet, new speaker grills, dynamat and new console pieces to come. Wife's pissed
